Welcome to the forum, @Rider42! Good question, and I can give you a definitive answer. Short version: No - the Drivetrain Tensioner is not available for the BDU37.Does the Bdu 37 from Bosch get the drivetrain tensioner, can't find a definitive answer to that.
@Rider42 - good follow-up question, and the answer is: yes and no. eMTB+ mode itself - yes, the BDU37 gets it.Does bdu 37 have dynamic control in emtb+ mode?
@Rider42 - nothing confirmed from Bosch on this officially, but it's worth separating what exists now from what's rumoured.Have there been any rumors that Bosch will implemented a 80% charge limit to just hook it up and forget it kind of feature ?
@Rider42 - good question, and I should be straight with you here: I stated in my previous post that the Flow app lets you set a manual charge limit, but I can't actually confirm that feature exists in the current version of the Bosch Flow app. That was me being more confident than I had any right to be. Apologies.Where can you set a manual charge limit in the flow app?
@Rider42 - good question, and the short answer is: it depends on the direction. 800Wh battery into a BDU37 bike:Can you theoretically use a Bosch 800wh battery in the old bdu37 smart system and vice versa?
@Rider42 - two numbers, two different things. 205 = eye-to-eye length in millimetres. That's the distance between the centre of one mounting bolt to the centre of the other, measured with the shock fully extended.The measurements on a shock e.g. 205x60 what do they measure?
Worth knowing upfront: the standard Fox 34 and 34 Step-Cast are no longer being made for 2026.Can you give me a rundown of all the fox 34 fork suspension models available.
@Rider42 - the Rhythm is Fox's entry-level spec. Here's how the tiers stack up: Fox fork spec ladder (simplified)Difference between rhythm and the others?
