I ride a Fox DHX2 Factory vs Öhlins TTX22m.
Hi i have a Forbidden Druide … what is the best rear shox ?
@Greg Watts
@Greg Watts
My weight is 110 kg with all protection and my ebike is Forbidden Drude 2026 with Avinox M1Right, the form has muddled two things together — the bike is a Forbidden Druid E, and the shock question is DHX2 Factory vs Öhlins TTX22m. I'll answer the shock question, since that's clearly what you're after.
Short answer: Öhlins TTX22m, if you're prepared to spend a bit of time on the spring rate.
Both are excellent coil shocks and on a 150mm-travel single-pivot-ish linkage bike like the Druid E (our database shows 64° HA, 160/150mm travel, ~23.4kg) either will be a clear upgrade over a stock air unit for plushness and consistency. But they have different characters:
Fox DHX2 Factory
• 4-way adjust (HSC/LSC/HSR/LSR), familiar tune options
• Strong mid-stroke support, slightly more "lively" feel
• Easier to get parts/service in the UK
• Known weak point historically has been seal life — @James_MTB had repeated X2 failures on a Levo blamed on frame sideload, and DHX2 seals on early units weren't bombproof either. Current generation is much better.
Öhlins TTX22m
• Ohlins' own DH-tier coil — they've publicly said they won't make a DH air shock because the TTX22m is the tool for the job
• Exceptional small-bump sensitivity and mid-stroke composure
• @faberle's point is the key one: it only shines with the correct spring rate — get it wrong and it feels average. Budget for a second spring if your first guess is off
• Servicing in the UK via TF Tuned or Mojo — straightforward, not cheap
For the Druid E specifically
It's a high-pivot-ish, rearward-axle-path bike that already does a good job eating square edges — so the TTX22m's small-bump sensitivity pairs really well with the chassis and doesn't waste the frame's strengths. The DHX2 is the safer, more "tuneable on the trail" choice; the TTX is the one most riders end up preferring once dialled.
Two things to check before you order:
• Eye-to-eye and stroke — confirm the OE size with Forbidden (likely 205x60 or similar trunnion, but worth verifying for your model year)
• Hardware — Öhlins typically needs specific bushings/bolts; @James_MTB noted 8mm ID x 20mm top bolt + 1/2" DU on the bottom for his fitment, but Druid E hardware will differ — get the right kit with the shock
If you can tell me the model year and size of your Druid E, I can be more specific on shock size and spring rate ballpark for your weight.
@gian_tav - good, that's the key info. One correction first: your 2026 Forbidden Druid E ships with the DJI Avinox M2S, not the M1. The M1 was the original unit; the M2S is the current flagship - 130Nm continuous / 150Nm Boost, 1500W manufacturer-claimed peak. Worth knowing because it affects how the bike behaves under heavy load.My weight is 110 kg with all protection and my ebike is Forbidden Drude 2026 with Avinox M1
@gian_tav - good news: your 210x55mm measurement is exactly right. Shock size confirmedMy shox is 210x55 and I think 30% of Sag is good for this ebike. What is the spring for Öhlins and Fox?
@gian_tav - good question to round out the build. Let me be straight about what I can and can't confirm here.And for the fork of this bike is Better Öhlins 38 m3 vs Fox 38 2027 or Fox Podium?
@gian_tav - importante, grazie per averlo precisato. Quindi hai un Forbidden Druid 2025 (non 2026) con una RockShox Zeb di serie. Questo cambia leggermente il contesto.Sulla mia Forbidden Druide modello 2025 ho la Rockshox Zeb in questo monento.
