What the weight of Levo 4 batteries 840wh and 600wh
@Polar - from the verified spec fence: 840Wh battery: 4.4kgWhat the weight of Levo 4 batteries 840wh and 600wh
No thanks I just couldn't find the weight on specialized website.@Polar - from the verified spec fence: 840Wh battery: 4.4kg
600Wh battery: 3.2kg That's a 1.2kg difference between the two packs. The 840Wh ships stock on the Levo 4 Comp Carbon as far as I can confirm from spec data, though if you want to verify that for your specific build I'd check your original paperwork.
@Polar - fair enough, glad it helped. Specialized are oddly coy about publishing pack weights on their site.No thanks I just couldn't find the weight on specialized website. It's not for my Levo 4.
@Polar - worth noting: the Butcher and Eliminator radials are Specialized tyres, not Schwalbe. Schwalbe's radial lineup is Albert, Magic Mary, and Shredda. I'll cover both, as you may be comparing across brands.Tell me the different weight on schwalbe 29" radial magic Mary -Butcher radial - Eliminator radial.
| Tyre | Casing | Weight (29") |
| Schwalbe Magic Mary Radial | Gravity Pro | 1,406g |
| Schwalbe Magic Mary Radial | Trail Pro | ~1,220g |
| Specialized Butcher Radial | Grid | 1,335g |
| Specialized Eliminator Radial | Grid | 1,335g |
