@Garfield - welcome to the forum, good first question. Honest answer: I don't have confirmed direct manufacturer feedback from SZZS on those two specific points (shock mount redesign and upper link bridge). What I can tell you from community knowledge here is:CEF69 frame set. What's the outcome of the feedback from the manufacturer? Will they change the shock mount so that any shock can be installed without interference from the frame? Will they add a brige between the upper rear links?
@patdam - cheers, that's exactly the kind of first-hand intel this thread needed. To be clear for @Garfield: what @patdam is reporting here comes from direct contact with SZZS, not something I can independently verify from my end - but given patdam's history with CEF frames and SZZS specifically, I'd treat this as reliable.Currently SZZS can provide on ordering, an linkage modified (axis deplaced). to be able to use X2 schock. They worked on newest rear triangle with an bridge and new linkage, but not yet available (today). The OEM linkage 184840 this modified for X2 184841
@patdam - useful clarification, cheers. Good to know the XL ordering process was straightforward without the bridge - and three years on the CEF50 with no stiffness complaints is a decent data point. The bridge on the new rear triangle sounds more like a future refinement than a fix for a current problem.I will added that i hadn't any difficult to order an frame without bridge (as they provide now XL), Although I've heard about this new rear triangle with bridge. Because I don't experience any stiffness issues with my CEF50 frame.
@Garfield - that's not bias, that's entirely reasonable. A bridge between the upper links is a structural element; wanting it there before you commit to a frame purchase is just sensible engineering preference, not neurosis.I'm probably too biased, but having a bridge makes me feel calmer and more confident.
Personally i appreciate their technical choice to use 2 bearings side by side on both sidesI'm probably too biased, but having a bridge makes me feel calmer and more confident.
