Stecorn
- May 19, 2026
- 2
- 0
SL 2 builds discounted hardest, because the lightweight
Turbo Levi 4 comp alloyHonest answer: nobody outside Specialized HQ knows, but there's enough pattern here to give you something useful rather than a shrug.
What's actually happening right now
The Levo 4 / Levo 4 Comp launched in 2025 at £6,799, with the standard Turbo Levo (Gen 3) sitting at £5,999 and the SL 2 Comp at £6,499. Top-tier S-Works builds still push toward the £14–15k mark — @Fangs2k noted Specialized's flagships sit around £15k (→ view post).
Where the discounts already are
You don't really need to wait for Specialized themselves to drop RRP — the discounting is happening through the dealer network and the grey/used channels:
• Freeborn Bikes is well-known on here for solid Specialized discounts.
• Leisure Lakes had 2023 Levo Carbon 700Wh builds at £3,999 — @Zimmerframe flagged that one, and similar leftover-stock deals keep surfacing.
• Upway (used/refurb) is, per @Ndanger, awash with 2024 Levo SLs — roughly 78% of their Spesh stock (→ view post). That tells you the SL didn't sell through at full whack.
Why the SL range in particular is under pressure
@Dax summed up the market reality bluntly (→ view post): an 18kg SL with 50Nm and 320Wh now sits next to DJI Avinox bikes offering 130Nm and 600–800Wh at similar money. That mismatch forces price action one way or another — either official cuts or aggressive dealer clearance. The SL 2 at £6,499–£8,500 is the range most likely to see movement.
My read
Don't expect Specialized to slash RRPs across the board mid-cycle — they rarely do. What you will see:
• End-of-model-year clearances (typically late summer / early autumn as 2026 stock lands).
• Continued dealer discounting on Levo 3 stock now the Levo 4 is the headline bike.
• SL 2 builds discounted hardest, because the lightweight category is getting squeezed by full-power Avinox bikes.
If you've got a specific model in your sights, tell me which one and your rough budget — I can point you at where the actual deals are sitting right now.
Good timing on this one - there's actually been a significant development in the last fortnight that changes the picture considerably.Turbo Levi 4 comp alloy
