what would the main difference be between my Amflow Carbonpro 2025 and Pivot shuttle AMPT I'm considering purchasing this bike.
EdK
what would the main difference be between my Amflow Carbonpro 2025 and Pivot shuttle AMPT I'm considering purchasing this bike. I am 5'5", weight about 170?
Good question, and a fairly significant step up in both ambition and price point. Let me web search the current specs on both bikes - particularly the Pivot Shuttle AMPd motor and sizing for someone at 5'5" / 170 lbs - before I give you numbers.
[Based on search results for Pivot Shuttle AMPd 2025/2026 specs and Amflow Carbon Pro 2025 geometry]
Here's where things stand. I need to be straight with you: the Avinox M2S torque figures are contested in my data - I have conflicting claims ranging from 120 Nm to 150 Nm, and I can't confirm which is current and accurate. I'll flag that clearly below rather than pick a number I can't stand behind.
Motor
BikeMotorTorque
Amflow PL Carbon Pro 2025DJI Avinox M1120 Nm
Pivot Shuttle AMPdDJI Avinox M2SUnconfirmed - claimed 150 Nm but I can't verify that figure
Both are DJI Avinox platform, which means the same app ecosystem, same integration philosophy. The M2S is the newer, higher-output variant - but the exact peak torque is something I'd check against DJI's current spec sheet before buying on that basis.
The meaningful differencesMotor: M2S vs M1 - the AMPd has the newer, more powerful motor. If you want the cutting edge of the Avinox platform, that's the Pivot.
Battery: Both 800Wh - no difference there. • Travel: Both 160/150mm - essentially the same category.
Weight: Amflow PL Carbon Pro comes in around 19.7 kg (size L, per Pinkbike's verified figure). Our database shows the AMPd at 21.5 kg, though that's unverified - treat it as approximate.
Price: Our database shows the AMPd at ~£7,504 vs the Amflow at £5,999. That's a £1,500 gap - worth knowing what you're paying the premium for.
Sizing - this matters at 5'5" At 5'5" (roughly 165 cm) you're likely looking at a Small on the Amflow Carbon Pro. The AMPd sizing I'd need to confirm - Pivot's size charts can vary by model. I'd strongly recommend checking Pivot's geometry table for the AMPd specifically and comparing reach/stack on the Small before committing. Don't assume S on one is S on the other.
Bottom line You're not trading up dramatically in capability - same travel, same battery, same platform family. The AMPd gets you the newer M2S motor and a different frame/brand. Whether that justifies ~£1,500 more depends on how much the motor upgrade matters to you and whether your dealer support for Pivot is solid. As @RustyIron's post noted in a related thread - dealer network and parts availability are worth factoring in alongside the spec sheet.
    668K
