Yamaha pwx3 motor with x interface, speed is sporatic, slowly turning the wheel shows 5 up to 80
kelvinkml
Yamaha pwx3 motor with x interface, speed is sporatic, slowly turning the wheel shows 5 up to 80 and is causing the motor to cut out when pedaling even when going walking pace in the lowest gear
Welcome to the forum, @kelvinkml - classic first post: straight to a real problem, no messing about.
Right. What you're describing - speed reading jumping between 5 and 80km/h while slowly turning the wheel - is a textbook faulty speed sensor signal. The motor uses that reading to decide when to cut assistance (it's legally required to stop helping at 25km/h), so when the speed sensor is damaged or misbehaving, the system limits drive output and can cut assistance prematurely - sometimes well before you've reached 25km/h, depending on gear.
The Interface X is simply the minimalist LED display/remote for the PW-X3 system - it's operated via a compact thumb remote and the LED display is typically mounted above or below the stem like a headset spacer.
It won't be causing this - the fault is almost certainly in the speed sensor circuit. Work through this in order:
Check the spoke magnet first. A twisted or misaligned spoke magnet on the rear wheel is the most commonly cited fault. Check it's properly aligned with the sensor - if the error persists with correct alignment, get the wiring and plug connection checked.
Inspect the sensor cable and connector. Look for any damage, pinching, or a loose plug at the motor end. The PW-X3 speed sensor includes the cable and connector as a single unit
- if the cable is damaged, it's a straightforward replacement part (around £25 - 35). • If the magnet and cable are fine, suspect the sensor itself.</cite>
The motor controller checks for an "alive" response from the speed sensor at startup - the bike may power up and run briefly before cutting out, because the sensor was connected but not actually functioning correctly. That points to the sensor itself being at fault, not a wiring issue.
Worst case: controller fault inside the motor. If a new sensor doesn't fix it, the issue can be internal. Yamaha diagnostic software can read fault codes from the PW-X3 - worth getting a dealer to plug in before committing to a motor swap.
Yamaha motors are generally very reliable and faults in the motor itself are much less frequent - so start with the cheap end first.
What's the bike's age/mileage, and has it taken any knocks or had a wheel out recently? That'd help narrow it down.
the bike is brand new, straight out of the box, the magnet is disc brake mounted so shouldn't be an issue with alignment
@kelvinkml Brand new out of the box and already showing erratic speed readings - that changes things significantly. This isn't a worn sensor or a knocked magnet; it's a factory defect or assembly error.
With a disc-brake-mounted magnet (a fixed ring on the rotor spider rather than a spoke magnet), misalignment is less likely - but not impossible. The signal disc still needs to sit at the correct gap from the sensor. On a brand new bike it's worth checking:
• Signal disc spacing - there's a known issue (not Yamaha-specific) where the signal disc sits too close to the brake rotor, causing interference. One user in our community found 1mm spacers between the signal disc and brake disc solved an identical erratic speed reading problem on a new build.
• Sensor connector seating - even on new bikes, connectors can be unseated during assembly or transit. Unplug and firmly reseat the speed sensor connector at the motor end.
• Cable routing damage - check the sensor cable hasn't been pinched during assembly. If none of that resolves it, this is straightforwardly a warranty job. Don't spend time chasing a fault on a new bike - return it to the retailer. A brand new PW-X3 system throwing speed errors from day one should be replaced under warranty without argument, not diagnosed around.
Which retailer did you buy from?
