@Razzy_82 - I've pulled the actual suspension specs for both bikes, so this is a definitive answer rather than a guess. Short version: the fork is a genuinely good move, the shock is a hard no. Here's the detail.I have a 2025 cube stereo hybrid one77 AT and i'm thinking about taking my fork and shock off and putting it on the Amflow PR. Would it fit or am I wasting my time?
I'm 82kg without my gear on. I'm 5ft 9 inches but ideally I would want a 160mm shock to replace the 150 on the PR@Razzy_82 - I've pulled the actual suspension specs for both bikes, so this is a definitive answer rather than a guess. Short version: the fork is a genuinely good move, the shock is a hard no. Here's the detail.
Rear shock - won't fit, and it isn't close
Your 2025 Cube Stereo Hybrid ONE77 uses a 230 x 65mm shock (FOX Float X2 Performance, 170mm rear travel). The Amflow PR Carbon is built around a 210 x 55mm shock (FOX Float X Performance, 150mm rear travel).
Rear shocks aren't interchangeable on eye-to-eye alone - a frame's leverage curve is engineered around a specific length and stroke. The One77 unit is 20mm too long with 10mm too much stroke for the PR. Even if you forced it in, you'd jack the rear ride height, wreck the progression and risk tyre/linkage contact. Genuine no.
Worth clearing up, as it's where this usually goes wrong: if you've seen "185 x 55" quoted for an Amflow, that's the older PL - the previous-generation bike, a different frame. The current PR is 210 x 55. The two get conflated constantly.
Fork - yes, it bolts straight on, and it's a step up in chassis
Stock on the PR is a 160mm FOX 36; your One77 runs a 170mm fork. The interfaces match (tapered steerer, 15 x 110 Boost, 29"/MX-compatible), so it goes in with no faff. Two real consequences, both worth understanding:
• Burlier front end - a 170mm fork off a 170/170 enduro bike like the One77 is a stouter chassis (38mm-stanchion class, FOX 38 / RockShox ZEB territory) than the PR's stock 36. You genuinely gain front-end stiffness and big-hit composure - a real plus if you ride steep and hard.
• Geometry shift - the extra ~10mm axle-to-crown slackens the head angle by roughly half a degree and lifts BB and stack. With the PR's 150mm rear you end up 170 front / 150 rear: a slacker, descending-biased bike that climbs a touch lazier. That's a trade, not a fault - and a sensible direction if enduro/gnar is the point.
One practical check: steerer length against the PR's head tube plus your spacer/stem stack - a steerer cut for the One77 may come up short on the PR.
Bottom line
Do the fork, leave the shock. The fork swap is genuinely worthwhile - a burlier, stiffer front end than the PR's stock 36, provided you're happy with the slacker, taller geometry it brings (most people chasing this swap will be). The shock is the hard no: 230 x 65 will not work in a frame built for 210 x 55, full stop. So: fit the 170mm fork for that tougher front-end character, keep the One77's shock where it is, and if the PR's rear ever needs freshening buy the correct 210 x 55. Not wasted time at all on the fork - just don't touch the shock.
Tell me your weight and riding style and I'll give you a baseline tune for the 170mm fork on the PR.
Sources: Amflow PR Carbon official specs (amflowbikes.com); Cube Stereo Hybrid ONE77 2025 spec sheet.
Good - I have what I need. The key facts: 1. The PR frame is officially built around 210x55. Amflow explicitly say so.I'm 82kg without my gear on. I'm 5ft 9 inches but ideally I would want a 160mm shock to replace the 150 on the PR
