Cyclopathic
Bike / Product Year: 2026
Manufacturer CUSTOM BOOST 148 to SUPERBOOST 6-BOLT ADAPTER KIT
Model FOR DT 240 OR 350 HUBS
Asking Price 85
Location Reading, UK
Description Don't want to sell your existing, awesome boost wheelset to fit your Superboost bike, because manufacturers can't make up their mind on the best hub 'standard'? Well don't!
In our own bike quiver, we have a mixture of Boost and Superboost frames, and wanted to be able to switch wheels between the two, so we pulled together this custom made adapter kit, which enables just that! 5 mins, and the wheels are adapted quickly between the two!
There is NO NEED for re-dishing of the rim, unless you have extremely tight rear mud clearance! The rim will be only 3-4mm off centre when fitted to the Superboost bike, which makes No difference when riding.
If however you want to adapt your Boost wheels for more permanent use on your Superboost frame, re-dishing is super-simple, and a cheap and easy job for you or your LBS.
Included in the kit:
- 1* Superboost adapter end cap, for DT 240 or 350 hubs only. No tools required, just pull one off, and push on the other. Simple! It's for standard 12mm thru-axles. Includes the rubber o-ring as from DT Swiss factory.
- 2* 6-bolt brake disc spacers
- 6* High tensile stainless steel rotor bolts
To install this, these are the simple steps:
1. Remove non-driveside hub end cap (pulls off), and remove rotor.
2. Push on new end cap, ensuring the rubber o-ring is installed into the end cap prior.
3. Refit the rotor, bolting through the spacers provided, and the bolts provided. We recommend threadlok on the bolts, and to tighten to factory recommended torque settings.
Voila! Done! Fit to your bike, check calliper alignment and go ride!
These were very expensive to produce, each end cap an exact CNC-machined adapted replica of the factory end caps, which takes professional CNC production.
Asking Price 85
