Shimano EP8 not turning on
mikeabbott51
Shimano EPB not turning on
Here's what Greg had to say:
Welcome aboard, mikeabbott51. Assuming you mean EP8 (or possibly EP801) — let's get you riding rather than pushing.
The 30-second checklist
Bumped cranks? If there's any pedal pressure when you hit the power button, Shimano motors throw E010 / E020 / E201 and refuse to wake up. Take your foot off, rotate the cranks to a neutral position, then power on. @TwoWheeln flagged this exact behaviour on EP801.
Battery seated properly? Pop it out, inspect the Rosenberger contacts for dirt or moisture, re-seat firmly until it clicks. A poor seat is the single most common "dead bike" cause.
Try the power-on reset: remove battery, hold the power button for 10 seconds, refit battery, try again. @Zimmerframe's trick — if it boots, the motor control board is fine.
Charge it. Sounds obvious, but BMS sleep mode after long storage will make a battery present as flat-dead. Stick it on the charger for 10 minutes and try again — even a brief top-up is often enough to wake the BMS.
If none of that works
The Shimano EP8/EP801 system is one enclosed electrical loop — as @Rod B. put it, if any wire or connection is bad anywhere, the whole bike sulks. Suspects, in order of likelihood:
Battery wiring harness under the motor cover — pinched or chafed wires are rampant
On/off switch cable to the head unit
Speed sensor / magnet alignment
Water ingress at the battery connector (very common after jet-washing)
@Martin Sadecký's diagnostic order for EP801 shutdowns is: battery harness → power button → motor-to-display cable. Worth working through in that sequence.
Get the error codes read
Even if the bike's currently dead, once it boots, any Shimano dealer with E-Tube can pull the fault log. There will be codes — the system logs everything. Don't let a shop poke about blind; insist on a log readout first. It turns guesswork into a 10-minute fix.
One known nasty: BT-EN806 batteries with failing BMS will let the bike boot, run for 30–60 minutes, then cut out and refuse to restart until briefly plugged into a charger. If that matches your symptoms, the battery itself is the suspect.
What bike is it on, and does anything happen when you press the power button — any LEDs, beeps, screen flicker? That'll narrow it down fast.
Green light on power button comes on then goes off. Display dead.
