Analysis Paralysis - First eMTB
WaldoJ
Hello everyone,
I am in the market for my first eMTB. I live in North Georgia and have good trail systems like Chicopee Woods and beyond. I want a full-power eMTB and have too many options to choose from. I just want to ride!
About me: I am male 5'8" and 225lbs and trending down. I seem to fit a medium frame from just about every manufacturer fine. S3 on the Specialized side. I rented a Mondraker Chaser R and liked it, but I felt really high off the ground. The Bosch motor was excellent though.
Here is where my analysis paralysis kicks in. I have several offers on the table and I want to make the best decision for my wallet. I am not on an N+1 budget, but I do have $5000 and can flex a little above if the bike is worth it.
1. 2026 Specialized Turbo Levo Alloy - $4999- I tried to test ride this one, but they gave me a carbon frame instead. It was $8500 so way out of price range. Power was exceptional and I know it has the same motor as the Levo Alloy.
2. 2025 Mondraker Chaser R $4750 - This is the bike I rented. I liked the bosch motor. It was smooth and as silent as I could have hoped for. I did feel like I sat really high on it and maybe too far over the handlebars.
3. 2025 Mondraker Race $5250 - Medium frame but have not ridden this one. Has the SX Race motor in it.
4. 2025 Mondraker Crusher RR $5850 - This is overkill for me. I know it, but the deal seems solid so thought I'd include it. Not excited about the Shimano motor. The rattling would drive me crazy on descents.
5. Cannondale Moterra Carbon 2 $4600- Not been on it or even seen it. Its within the budget and has a Bosch motor.
All bikes are new so warranty is in play for all of them.
Help!
What's your current bike?
Your going to get all different answers which won't help you narrow it down. 5'8" puts you on a "medium" size bike usually or S2/3 depending on manufacturer. Again, what's your current bike and you can relate the geometry to it.
Honestly just pick one and live with it.... you'll adapt and learn what you like and don't like. Without a history of riding different bikes, sometimes its impossible to know exactly what you'll prefer.
Mondraker do run "longer" reaches, but with shorter stems I believe. I checked the Chaser R and the BB height at 350 is pretty normal I'd say for a bike in that travel range. 470 mm reach, maybe a touch on the longer side for someone at 5'8" depending on body proportions and preferences. In the past 450 'ish would have been a medium reach and today many are pushing towards 460-470 mm. You can adapt. You can also raise the bar height to fell less over the front.
Specialzied will have a ton of local support abnd dealers, pretty ubiqoutous. The downside of the alloy will be weight... but many full power eMTBs are nearer 48-53 lbs on the carbon side. Ask yourself if you need or want a 160/170mm full power eMTB vs. an SL shorter travel option.
Shimano motors work great and usually its the 3rd party batteries that are problematic. If I was buying today, I would avoid Shimano just because it older and the least serviceable option. I'd stick with Bosch CX or Avinox for a full power system. Unless your getting a killer deal and can "live" with only 85Nm and 600W... joke, because they are still plenty powerful.
Good advice above. Along with Avinox and Bosch based systems I'd add Specialized as a safe choice as well. That Turbo Levo is a solid bike and the extra weight is pretty meaningless with a powerful emtb.
Emtb issues are rare but can be complex. Most of your choices above are pretty good. If you can't decide on the bike, choose whatever one has the best local support.
For its price I think the PR Carbon ( $4,999 ) is pretty solid. Much more modern system and lighter carbon piece of kit. Im not american so dont know about avaliblty though. Compared to the prices of the bikes you listed I would say the Amflow is quite a bit a head im most metrics. The specs are not amazing for the base bike though.
To keep it simple you should try and find a reach number that you like. For you I would guess around 460 cm and go with that when choosing a bike. Fit is very important
Thank you for the advice! The Amflow looks like a solid bike and I would love to have one but they are all sold out here in the US. I’m also not certain of any local support for them in my area. That is a big hesitation as I get into the sport and try to learn.
My current bike is a Trek Allant+ 7S medium frame and I like it quite a lot.
I also appreciate the “pick one” thought. It’s easy to get lost in my head and at times I don’t even realize that no mountain bike is the darkest timeline.
You honestly can't go wrong with Bosch, Specialized or Avinox. If you have no one that works on Avinox bikes locally then that'd be a big mark against them.
Since you're new, I'd see if there are any good deals on a used e-bike. You can spend way less money, get a very capable bike, and learn what you like before you buy a new one in a year or more. This is especially true now because I think Avinox is taking over and are the best system, but the availability on their new stuff is low/non-existant. I personally would not want to settle for second best because supply hasn't arrived yet.
Hello everyone,
Consider what you ride now, and use that as a starting point. You can go with a burlier eMTB because you'll no longer be limited by your own physical strength. You'll have more power and more speed, so you'll be needing a bike that can handle that. Your skills will improve, as well.
Weight isn't as much of a consideration as it is on your Amish bike. You can have grippier tires and more suspension, and not be held back.
The brand is going to be more a matter of geography. Most important, you want a dealer nearby who can help you if things go awry. Also, the manufacturer needs to have a presence in your region. Some manufacturers are strictly European. They might make great bikes, but it's a bummer if you have to wait several weeks for them to send you a part. Around here, I've not seen a Mondraker or Cannondale dealer. They might be around, though. But Specialized dealers are all over and they can deliver parts in a matter of days.
That's a shame, in Europe at least you can get a decent full suspension e-mtb these days for sub 3.5k EUR. Personally, I usually go cheap or expensive, but that's just me. I would try and find a good deal online for a cheaper alloy e-mtb. As long as it fits, I'm sure you will be happy. More expensive bikes that seem beginner-friendly: amflow, mondraker crafty, levo 4 comp carbon (600wh preferred)
Cyberbike. I am biased as the owner of the company, but we are an American, family-owned brand and offer an exceptional value. The newest models use very powerful, quiet and reliable Ananda motors, premium gearsets, and we have well-regarded, US-based support...although you may wish to upgrade the fork if you are a serious rider. Thank you.
I appreciate your honesty about the bias. I am curious what your warranty looks like as a DTC company. Say, my motor fails or something happens with the frame, what then? I can't just take it to a local bike shop for warranty service and I don't yet have the skills to swap out components to a new frame.
I have a Moterra and it's a comfy bike. Pretty sure the reach is less than the Amflow but honestly, you can just change stem/bar config to fix this on most bikes that are "short."
Our motor/battery warranty is 2 years. The labor is not covered but the part is. We recently changed motor suppliers because- while they were great at supplying replacement motors- they needed to supply waaaay too many. So, we have a great track record of supporting such issues. It Isn't free, but it's very solid coverage, and from what I see on the forums with the legacy brands, an improvement overall. As for batteries, we expected a lot of replacements. We have them on the shelf, but they seldom fail.
    668K
