Husqvarna MC4 Shimano motor error code 299 — can it be reset?
Short answer: no, you can't reset it yourself. And I'm afraid that's not me being lazy — it's by design.
What E299 actually is
E299 is Shimano's anti-tamper flag. The EP8/EP801 firmware decided, rightly or wrongly, that something on the system looked like a derestriction attempt (a tuning dongle, a dodgy speed sensor reading, a wheel-size mismatch, electronic gearing miscalculating expected vs actual speed, etc.) and threw the tripwire. Once it's set, it's written to Non-Volatile Memory inside the drive unit.
Why disconnecting the battery won't save you
As @Astro66 has explained on here, NVM is exactly what it says on the tin — non-volatile. Pulling the battery for a weekend, a month, even a year won't clear it. The estimate floating around is 12+ months of full disconnection might wipe it, and by then you'd have lost the firmware too. Not a fix.
Only Shimano's internal service tool (not E-Tube, not the SM-PCE02 you can buy) can clear E299. Dealers don't have it. You don't have it. The bloke on YouTube doesn't have it.
What you're looking at
• Bike goes back to a Shimano-authorised service centre
• Motor typically gets replaced, not repaired@Backflip has noted this is the standard outcome
• If the system thinks you tampered, warranty is likely void and you pay for the replacement motor
• If you genuinely didn't tamper, push hard for a goodwill claim — document everything
Before you send it in, sanity-check this
• Did you (or a previous owner) ever fit a SpeedBox, PearTune, MBIQ, BadAss, RedPad or Planet3? On EP801 those guarantee E295/E299 and flag the motor permanently
• Running electronic gearing (Di2/AXS) with an incorrect chainring or cassette config? The motor calculates expected speed from gear ratios — if reality doesn't match, it assumes derestriction
• Non-standard speed sensor magnet (e.g. swapped to Centerlock rotors without a proper magnet)? @Bndit found Galfer CL or Specialized CL lock magnets are the safe options
If none of those apply, you've got a leg to stand on with Shimano. If one does, brace yourself.
What bike is it on, and is there any tuning/dongle history you know of? That'll shape whether this is a warranty fight or a wallet event.
My bike is a Husqvarna MC4.
I am getting error code 299 on the shimano motor system. Can this be resetted?
@Greg Watts
@Greg Watts already did bring things together in a very good way. Thanks Greg - you have done very well! (y)
@stephan.phaneuf
Welcome to the forum!
So most probably you have used one of these "crappy dongles" (external electronic hardware box) Greg already have mentioned on your DU-EP801 based Husqvarna bike to speed up your bike instead of using a really error-free and hassle-free working and forever lasting tuning tool.
I had written many forum posts about this topic already.
I just wanted to mention that you never, ever should ignore the preceding 4 times E295 errors which finally will result in the fatal E299 error which will completely lock your drive unit and so makes the bike next to unuseable!
I know this is too late for you now and you have to send your bike or drive unit to a Shimano service centre.
However, for all other readers: Never, ever just ignore an E295 error on a Shimano STePS based bike (even if the bike will start again after a power on cycle) and check instantly what´s wrong, otherwise definitely the final fatal E299 will result and this will cause a lot of frustration then...
@Greg Watts already did bring things together in a very good way. Thanks Greg - you have done very well! (y) @stephan.phaneuf Welcome to the forum. So most probably you have used one of these "crappy dongles" (external electronic hardware box) Greg already have mentioned on your DU-EP801 based Husqv...
@Backflip - cheers, and well said on all counts. Good to have someone who actually knows the EP801's architecture inside out backing this up.
Good news for @stephan.phaneuf: the MC4 is confirmed as a DU-EP801-based bike - Husqvarna houses the EP801 in an upright position specifically to improve passive cooling, so everything we've said about the EP801's NVM flag behaviour applies directly to his situation. No ambiguity on the platform.
And @Backflip's point about E295 is the one I'd underline in red for anyone reading this thread later. The E295 → E299 escalation path is not a surprise - it's a four-strikes-and-you're-out system, and Shimano isn't subtle about it. As @MOG's post spells out from painful personal experience: "I had exactly the same experience... it is just a matter of when."
On the eMax-Tuning link @stephan.phaneuf dropped in - worth clarifying for the thread: that's eMax's product homepage, and it will not help with E299. eMax is a legitimate tuning tool for EP801/EP600 bikes on appropriate firmware, and @Backflip has covered its capabilities thoroughly elsewhere on the forum. But E299 is a motor-level lockout, not a firmware parameter - no tuning software of any flavour touches it. That fight is with Shimano directly, not a Windows app.
Krótka odpowiedź: nie, nie da się tego zresetować samemu. I obawiam się, że to nie moje lenistwo – tak to zostało zaprojektowane.
Czym właściwie jest E299
E299 to flaga antysabotażowa Shimano. Oprogramowanie układowe EP8/EP801 uznało, słusznie lub nie, że coś w systemie wygląda na próbę usunięcia ograniczeń (klucz sprzętowy do strojenia, wadliwy odczyt czujnika prędkości, niedopasowanie rozmiaru kół, elektroniczny układ przełożeń błędnie obliczający prędkość oczekiwaną w stosunku do rzeczywistej itp.) i uruchomiło alarm. Po ustawieniu, sygnał jest zapisywany w pamięci nieulotnej w jednostce napędowej .
Dlaczego odłączenie akumulatora nie uratuje Cię
Jak wyjaśnił @Astro66 tutaj, NVM to dokładnie to, co sugeruje nazwa – pamięć nieulotna. Wyjęcie baterii na weekend, miesiąc, a nawet rok nie usunie jej. Krążą krążące szacunki, że ponad 12 miesięcy całkowitego odłączenia może ją wyczyścić , a do tego czasu utracisz również oprogramowanie układowe. To nie jest rozwiązanie.
Tylko wewnętrzne narzędzie serwisowe Shimano (nie E-Tube ani SM-PCE02, które można kupić) może wyczyścić E299. Sprzedawcy go nie mają. Ty go nie masz. Facet na YouTube go nie ma.
Na co patrzysz
• Rower należy zwrócić do autoryzowanego serwisu Shimano
• Silnik zazwyczaj jest wymieniany, a nie naprawiany@Backflip zauważył, że jest to standardowy wynik
• Jeśli system uzna, że dokonałeś manipulacji, gwarancja prawdopodobnie straci ważność i będziesz musiał zapłacić za wymianę silnika
• Jeśli naprawdę nie manipulowałeś, staraj się o odszkodowanie za nieuczciwą działalność — udokumentuj wszystko
Zanim to wyślesz, sprawdź to pod kątem trzeźwości
• Czy Ty (lub poprzedni właściciel) kiedykolwiek montowałeś SpeedBox, PearTune, MBIQ, BadAss, RedPad lub Planet3? W EP801 te gwarantują E295/E299 i oznaczają silnik na stałe.
• Używasz elektronicznej przerzutki (Di2/AXS) z nieprawidłową konfiguracją tarczy lub kasety? Silnik oblicza oczekiwaną prędkość na podstawie przełożeń — jeśli rzeczywistość się nie zgadza, zakłada derestrykcję.
• Niestandardowy magnes czujnika prędkości (np. zamieniony na tarcze Centerlock bez odpowiedniego magnesu)? @Bndit stwierdził, że magnesy blokujące Galfer CL lub Specialized CL są bezpiecznymi opcjami
Jeśli żaden z tych punktów nie pasuje, masz szansę na sukces z Shimano. Jeśli jednak pasuje, przygotuj się.
Na jakim motocyklu to jest i czy znasz jakieś historie tuningu/kluczyków? To zadecyduje, czy będzie to walka o gwarancję, czy o portfel.
Mogę pomóc z błędem E299. Proszę o wiadomość prywatną.
@Shimanoboschexspert - heads up for @stephan.phaneuf and anyone else following this thread.
Posting twice to offer help via private message for an E299 error is a pattern we see from tuning box sellers. E299 on the EP801 is Shimano's anti-tamper flag - and as I've already covered in this thread, the only legitimate fix is an authorised service centre, not a PM from a stranger on the internet.
@stephan.phaneuf - please stick to the advice already in this thread. If someone's offering to "fix" E299 privately, the most likely outcome is your bike stays broken and your wallet gets lighter.
(Bilingual / Dwujęzycznie)
@Shimanoboschexspert[/URL] - uwaga dla @stephan.phaneuf i wszystkich obserwujących ten wątek. Oferowanie pomocy przy błędzie E299 przez prywatną wiadomość to schemat, który obserwujemy u sprzedawców pudełek tuningowych. E299 na EP801 to flaga antysabotażowa Shimano - jedyne legalne rozwiązanie to autoryzowany serwis, nie prywatna wiadomość od nieznajomego.
@stephan.phaneuf - proszę trzymać się porad już zawartych w tym wątku. Jeśli ktoś oferuje "naprawę" E299 prywatnie, najprawdopodobniej rower pozostanie zepsuty, a Twój portfel będzie lżejszy.
https://www.emtbforums.com/bike-finder/motors/5/avinox-avinox-m1
@Backflip – pozdrawiam i pod każdym względem dobrze powiedziane. Dobrze, że ktoś, kto zna architekturę EP801 od podszewki, to potwierdza.
Dobra wiadomość dla @stephan.phaneuf: potwierdzono, że MC4 będzie motocyklem opartym na układzie DU-EP801 – Husqvarna umieszcza EP801 w pozycji pionowej specjalnie po to, aby poprawić pasywne chłodzenie, więc wszystko, co powiedzieliśmy o zachowaniu flagi NVM w EP801, odnosi się bezpośrednio do jego sytuacji. Platforma nie pozostawia wątpliwości.
A uwaga @Backflip dotycząca E295 to ta, którą podkreślę na czerwono dla każdego, kto przeczyta ten wątek później. Ścieżka eskalacji z E295 do E299 nie jest zaskoczeniem – to system czterech ostrzeżeń i jesteś poza grą, a Shimano nie jest w tym subtelne. Jak wynika z bolesnego osobistego doświadczenia @MOG : „Miałem dokładnie to samo… to tylko kwestia czasu”.
W linku eMax-Tuning @stephan.phaneuf wtrącił się – warto to wyjaśnić w wątku: to strona główna produktu eMax i nie pomoże ona w przypadku E299 . eMax to legalne narzędzie do tuningu rowerów EP801/EP600 z odpowiednim oprogramowaniem, a @Backflip szczegółowo opisał jego możliwości w innym miejscu na forum. Ale E299 to blokada na poziomie silnika, a nie parametr oprogramowania układowego – żadne oprogramowanie do tuningu nie ma z nią nic wspólnego. Ta walka toczy się bezpośrednio z Shimano, a nie z aplikacją Windows.
@Shimanoboschexspert - this is now the third time you've posted the same message in this thread. I've already addressed it once, clearly and in both languages. Posting it again doesn't change the answer.
I'll be straightforward: this thread is visible to the whole community, and repeating a private-message offer for an E299 "fix" three times in a row is not a good look for a new member. If you have a genuine technical contribution to make about the EP801, you're very welcome to make it here, in the open, where everyone can benefit.
The advice for @stephan.phaneuf stands: authorised Shimano service centre, not a PM.
@Shimanoboschexspert - to jest już Twoja trzecia identyczna wiadomość w tym wątku. Odpowiedziałem na nią już raz, jasno i dwujęzycznie. Powtarzanie jej nie zmienia odpowiedzi.
Powiem wprost: jeśli masz prawdziwy wkład techniczny dotyczący EP801, chętnie go tu zobaczymy - publicznie, z korzyścią dla całej społeczności. Trzykrotna oferta "pomocy" przez prywatną wiadomość w sprawie E299 nie jest dobrym startem dla nowego członka forum.
Rada dla @stephan.phaneuf pozostaje niezmieniona: autoryzowany serwis Shimano, nie prywatna wiadomość.
Rozumiem Państwa obawy, ale niesprawiedliwe byłoby wrzucanie wszystkich do jednej kategorii. Posiadam wieloletnie doświadczenie w profesjonalnej diagnostyce i naprawie systemów rowerowych Bosch i Shimano. Każdy przypadek analizuję indywidualnie, a moje metody nie uszkadzają silnika ani żadnych innyc...
@Shimanoboschexspert - fair enough, and I'll take the point at face value: not everyone offering help via PM is selling snake oil.
But here's the thing. The invitation I've already made in this thread stands, and it's the genuinely better path: if you have real technical knowledge about E299 on the EP801 - what causes it, what the authorised reset procedure actually involves, any nuance about the architecture - share it here, publicly, where it helps everyone who ever searches this topic.
That's not a test or a trap. It's just how a forum works best. Knowledge posted openly helps the next hundred people who land on this thread with the same problem. A private message helps one person, and gives everyone else no way to evaluate whether the advice is sound.
If your method is legitimate and safe, it'll stand up to scrutiny in public. If it's something Shimano would consider unauthorised, then regardless of whether it's technically harmless, @stephan.phaneuf needs to make that informed choice with full information - not through a PM where neither I nor anyone else can see what's being offered.
So: the floor is yours. What's the actual fix, and how does it work?
Nie publikuję własnych procedur diagnostycznych ani metod naprawy. Mogę jedynie potwierdzić, że opierają się one na wieloletnim doświadczeniu praktycznym, zostały gruntownie przetestowane i są bezpieczne dla układu napędowego. Każdy rowerzysta ma prawo wybrać rozwiązanie, któremu najbardziej ufa w s...
@Shimanoboschexspert - that's a clear enough answer, and I'll take it at face value. You won't share your method publicly. That's your call. But it does mean @stephan.phaneuf - and anyone else reading this - has no way to evaluate what's being offered before committing to a private conversation with someone they don't know. "Trust me, I've tested it, it's safe" is precisely what you'd say whether it was legitimate or not. That's not an accusation; it's just the honest reality of why public verification matters on a forum.
The advice for @stephan.phaneuf[/URL] hasn't changed: an authorised Shimano service centre is the only route where you know exactly what's happening, what it costs, and what warranty implications follow. E299 on the EP801 is a serious flag - 85Nm and 600W is a lot of drivetrain to gamble with on the basis of a PM.
@Shimanoboschexspert - you're welcome to post here anytime, and if you ever do want to share something technical in the open, the thread's there for it.
[HR][/HR] [I]@stephan.phaneuf - jeśli chcesz wrócić z pytaniami po wizycie w serwisie, śmiało wróć do wątku. Powodzenia.[/I]
    672K
