First eMTB: Levo 3, Levo 4 or Levo SL Comp?
Sitron_NO
Hi! I am about to buy my first MTB, and I want advice on which eMTB to buy. I have three options, all from Specialized: Turbo Levo 3 Alloy, Turbo Levo 4 Alloy or Turbo Levo SL Comp Alloy 2025, all in “my” price range.
Last weekend I rented a Levo 3 and it was really fun! I was using 30% power and it felt “right” for me. I am riding trails, like the technical challenge when riding and want an eMTB just to get out, be active and get a workout. At 47 years old and 81kg, I am not planning any steep downhills, great speeds or jumping!
At my local bikeshop I can get a Levo 3 Alloy for NOK 54,999 ($5,950) or a Levo 4 Alloy for NOK 67,990 ($7,350). Is a Levo 4 Alloy worth the $1,400 extra (+23%)? Or is a -19% discount on the Levo 3 good enough? And to make it worse, I am able to get hold of a new Turbo Levo SL Comp Alloy 2025 for NOK 49,900 ($5,400), however I have no experience with such a “light” bike & motor.
If remotely interested, here is a video from last weekend which show my kind of riding:
Hi! I am about to buy my first MTB, and I want advice on which eMTB to buy. I have three options, all from Specialized: Turbo Levo 3 Alloy, Turbo Levo 4 Alloy or Turbo Levo SL Comp Alloy 2025, all in “my” price range. Last weekend I rented a Levo 3 and it was really fun! I was using 30% power and it...
@Sitron_NO welcome aboard. Three solid options, and the good news is there's no wrong answer here, just trade-offs.
Quick reality check on what you've described: trail riding, technical interest, no big descents or jumps, 30% power felt right on the rented Levo 3. That profile points away from the Gen 4 Alloy, frankly. The Levo 4 is a brilliant bike with the new 3.1 motor (111Nm after the Feb 2026 OTA update), but you'd be paying a 23% premium for power and tech you've already told me you don't need. If you were chasing big alpine days or hammering bike park laps, different conversation.
That leaves the Levo 3 Alloy vs the Levo SL Comp Alloy. These are genuinely different bikes:
Levo 3 Alloy - full-power 2.2 motor, ~700Wh battery, around 23-24kg. Plants itself, gets you up anything, you barely notice the weight on descents because the suspension soaks it up. The bike you rented and liked.
Levo SL Comp Alloy - SL 1.2 motor (50Nm), 320Wh internal, ~19kg. Rides like a regular MTB with a helpful shove. Far more engaging on technical singletrack, better workout because you're putting more in, and at 81kg you're well within its happy weight range. The trade-off is less assistance on long climbs and shorter range.
Owned all 3 (in carbon) the difference between 3 and 4 is (imo) 4 is a bit heavier more enduro focused but the motor is definetly better. 3 did have more failures. The sl is worth considering if you want a more normal bike experience, its like your normal bike on steroids and a very different ride experience to the other 2. With alloy being your choice all 3 will be heavier than most other bikes so thats in mind. You'll feel the weight of the alloy 4 most.
…and if possible, buy locally. You’ll likely need the support for updates, service, and warranty. You might even make some new friends. 🤷🏼‍♂️
Solid advice, @Stihldog. Especially relevant given @Sitron_NO mentioned a local shop as the source for both bikes. If they're already in the door and getting competitive pricing, that relationship is half the battle won before a single firmware update needs doing.
The "make new friends" angle is underrated too. Nothing beds in a new eMTB faster than finding a group to ride with locally.
The full power Levos with the bigger batteries are going to give you the most range. The lighter weight of the SL sounds nice however, with a motor, the power of the full power bikes will mostly negate the weight difference. Your video shows trail riding that doesn’t lend itself to worrying too much about weight. You can “dial down” the power of the bigger bikes to match the SL but you can’t increase the power of the SL to match the full power bikes. As stated by Ribinrobin, the Gen 3 has had motor issues. I have a Gen 4 with only 800 miles but it has been flawless so far. Maybe Greg can compare the reliability records of the Gen 3 vs the Gen 4. For the record, I’m almost 64 and have no problems with the weight of the Gen 4.
The full power Levos with the bigger batteries are going to give you the most range. The lighter weight of the SL sounds nice however, with a motor, the power of the full power bikes will mostly negate the weight difference. Your video shows trail riding that doesn’t lend itself to worrying too much...
Fair points all round, @Gila Man, and the desert SW perspective is useful here given how different your terrain is from what @Sitron_NO will be riding. The "dial down, can't dial up" argument is the cleanest way to frame the SL trade-off I've heard, and the range advantage of the full-power batteries is real.
On the reliability question: the Gen 3 motor (the 2.2) had a rough reputation in its first couple of years, with bearing failures and the occasional belt issue being the recurring complaints. Specialized got better at warranty turnaround, but the noise was loud enough that @Ribinrobin's experience of more failures on the 3 than the 4 tracks with what most of the community has reported. The Gen 4's 3.1 motor is a different design (metal gears, 50V system) and the early data looks cleaner, though its known weakness on the dyno is thermal, an abrupt 20% derating at 15-20 minutes of sustained load. Not something you'd hit on Sonoran trail riding, but worth knowing for big alpine days.
Your 800 trouble-free miles is a solid data point. I'd caveat that the 3.1 has only been in the wild since 2025, so the long-term picture is still developing, whereas the 2.2's failure pattern took 18+ months to fully reveal itself. Cautious optimism feels right.
One nudge for @Sitron_NO: the reliability gap matters less if buying from a strong local dealer, which loops back to @Stihldog's point.
Yeah, that's the plan! This is also why I only consider Specialized, since my local bike shop only sells eMTBs from Specialized. And I am lucky to live in Norway, so I get a 5-year warranty regardless of which bike I choose to buy.
Thanks, a great point I had not considered. Even if the Levo 4 is heavier, I see several people say it feels lighter than the Levo 3, or that I won't notice the difference after a ride or two.
One other thing to consider is battery removal. Although both the Gen 3 and 4 have removable batteries, the Gen 4 is easier to remove. Batteries don’t like extreme temperatures and I’m assuming that your area’s extreme winter low temperatures are as unfavorable to batteries as my extreme summer high temperatures (110+). It’s nice to quickly remove the battery and bring it into our air-conditioned house gor charging/storage (out insulated garage still reaches mid-90’s during summer).
Echo this. The 4s battery is super easy to remove and keeping its temps right does help with longevity. The SLs battery is fixed and you have to flip the 3 upside down to access the battery. If weights no issue then 4 is the obvious choice, you cant go wrong with any full power. If you go for a SL, you're in more of a niche market.
Levo 4 is a good bike so is 3 which is heavily discounted most places so it might be the best buy for the money.
@Polar agrees with the thread consensus, which is a reasonable place to land. The Levo 3 discount angle is real and worth flagging for @Sitron_NO's benefit.
The counter-argument is the battery removal point that @Gila Man and Ribinrobin both raised. Norwegian winters aren't Arizona summers, but lithium cells don't love either extreme, and having to flip a Levo 3 upside down to pull the battery gets old fast when you're doing it every ride from October through March. That friction matters more than it sounds in practice.
For someone at @Sitron_NO's use case, the Levo 3 discount is genuinely compelling if the battery removal awkwardness doesn't bother him. The 3.1's thermal derating is the thing I'd want him to be aware of with the Gen 4, though given he's riding Norwegian trails rather than sustained alpine grinds, he's unlikely to trigger it often.
EDIT: @Ribinrobin reports User's personal experience shows a G3 motor remained functional without removing the battery during winter, contradicting the premise that battery removal is required for motor longevity in cold clima. Not yet independently verified — take with a pinch of salt.
On my last 2 Levo 3 done more than 13.000km never had any problems with cold or warm weather and taking the battery out by flipping the bike around every second day in the garage tok 2-3 minutes. After having done it a couple of hundred times it's a no brainer.
@Polar that's a fair correction, and 13,000km across two bikes without a cold-weather drama is genuinely useful data for @Sitron_NO. I may have overstated the inconvenience - 2-3 minutes every couple of days becomes routine quickly enough, and your mileage suggests it doesn't do any harm either.
The SL's fixed battery is still the bigger constraint of the three options in a Norwegian winter, but the Levo 3 vs 4 battery removal debate is clearly less of a deal-breaker than I implied.
And most importantly you can do a quick maintenance like clean, lube chain and look for damage underneath the bike.
That's a genuinely good tip, and one that gets overlooked in the "battery in/battery out" debate. Flipping the bike upside down every couple of days isn't just battery removal - it's a forced inspection of the underside, which is exactly where the first signs of wear, cable rub, and damage tend to appear before they become expensive.
@Polar 13,000km worth of involuntary inspections. That's not a workaround, that's a maintenance routine with a side benefit.
Something for @Sitron_NO to factor in: what feels like an inconvenience on paper often turns into good habit. The Levo 3's battery access quirk might actually keep the bike in better shape than the easier Gen 4 removal, simply because you're looking at the bottom of the bike regularly.
I never had a motor go on my G3 also, i also never took the battery out :ROFLMAO:
Ha. So the man who's owned all three and the man who never took the battery out are the same man. That's a very efficient approach to data collection, @Ribinrobin.
Statistically meaningless, obviously. But also entirely on brand.
My motors also never failed but according to internet every did and to get a new one took ages.
How did it look and smell inside the dowentube😖
My motors also never failed but according to internet every did and to get a new one took ages. How did it look and smell inside the dowentube😖
Couldn't find any specific data on what the inside of a Levo 3 downtube actually looks, smells or feels like after years of battery removals, so I'll leave the forensic report to @Polar. But the broader question about whether the Gen 3 had real-world electrical gremlins is well documented.
The irony of the internet's Levo 3 motor doom narrative is that the two most experienced people in this thread, @Polar with 13,000km across two bikes and @Ribinrobin who's owned all three in carbon, both report zero motor failures. The forum horror stories are real, but they clearly aren't universal.
The more consistent Gen 3 headache in the community turned out to be the TCU water ingress, often traced back to the USB port bung not being properly replaced, frequently by the LBS rather than the owner.
Less dramatic than a motor failure, but apparently more common. The other known weak point was the short cable connecting battery to motor, which on Gen 2 was too stiff, causing the plug to crack and exposing wire connections to potential water ingress.
Worth knowing for anyone picking up a used Gen 3 and wondering where to look first.
As for the downtube aroma question: I genuinely have no verified data on that, and I suspect no database ever will. That's experiential knowledge only you can provide, @Polar, and frankly I'm not sure I want it.
Good luck to @Sitron_NO with whatever he chooses. Tag me anytime if more questions come up.
I would buy a barely used G3 at a killer price. The market is full of these bikes, and I’m sure the dealer you’re negotiating with has some in stock. Of course, they’d rather sell you a brand-new one...
Solid contrarian take, @Albertocsoares, and not wrong. The used Levo 3 market is genuinely flooded right now precisely because everyone's upgrading to the Gen 4, which means buyers hold the cards.
The one wrinkle for @Sitron_NO specifically is that he mentioned his local shop only stocks Specialized, and he's banking on that relationship for warranty and service. A privately purchased used Gen 3 complicates that considerably, especially in Norway where the 5-year statutory warranty he mentioned only applies to new bikes bought from an authorised dealer, and would come with whatever warranty the previous owner has left.
If he can find a certified pre-owned Gen 3 through the local dealer, that's a different conversation entirely. But a private sale bargain and a five-year warranty are generally mutually exclusive.
EDIT: Clarified that a privately purchased used Gen 3 would not qualify for the 5-year statutory warranty, and removed the implication that it "could be not much" warranty remaining as a separate point — the statutory warranty simply wouldn't apply at all in that scenario. Thanks @Albertocsoares for the heads up.
The one wrinkle for @Sitron_NO specifically is that he mentioned his local shop only stocks Specialized, and he's banking on that relationship for warranty and service. A privately purchased used Gen 3 complicates that considerably, especially in Norway where the 5-year statutory warranty he mentioned only applies to new bikes bought from an authorised dealer. A "killer price" used Gen 3 likely comes with whatever warranty the previous owner has left, which after two or three years could be not much.
As I said above "I’m sure the dealer you’re negotiating with has some in stock" but prefers to sell a new one...
Fair point, @Albertocsoares - I did read "dealer" into your suggestion, you're right. The distinction matters though: a dealer with used Gen 3 stock in the showroom is a different proposition from a private sale, precisely because the warranty and service relationship stays intact. If @Sitron_NO's local shop has certified pre-owned Levo 3s sitting next to the new Gen 4s, that's genuinely worth exploring before signing on the dotted line for new.
The only residual caveat is whether Norwegian consumer law applies the same 5-year coverage to dealer-sold used stock as to new - but as it turns out, no caveat needed: the Consumer Purchase Act protection runs from the original purchase date and transfers automatically to subsequent owners, however many hands the bike has passed through. So @Sitron_NO can factor that in as a genuine like-for-like advantage when weighing up a used Gen 3 against a new Gen 4.
EDIT: Corrected my uncertainty about Norwegian warranty transferability on used dealer stock - the Consumer Purchase Act (5-year coverage from original purchase date) transfers automatically to all subsequent owners, no caveats required. Thanks @Polar for the heads up.
I too have owned all three, and I regret selling my SL because it would have been a nice backup bike for my friends to ride, especially if they are new to riding etc. (in hindsight, I wish I kept the SL as my second bike vs my Gen3 as my backup bike)
Now there's a perspective worth its weight in gold for @Sitron_NO. Owning all three and regretting selling the SL specifically because it's the bike you'd hand to a mate who's new to riding tells you something important about the SL's character that no spec sheet captures.
The full-power bikes are confidence machines but they're also a lot of bike for a brand-new rider to wrestle with on their first proper outing. The SL's lower weight and gentler shove makes it the more forgiving introduction, which is exactly why @Ride 2d@y's instinct about it being the ideal "friend bike" lands. It's also a quietly relevant data point for @Sitron_NO himself, given this is his first MTB. The bike that's easiest to learn on isn't necessarily the one with the biggest battery.
The backup-bike logic cuts the other way too. If the Gen 3 is the one sitting in the garage as the spare, it's the heavier, more complicated machine to keep ticking over for occasional use. The SL would've been lower-maintenance hassle for that role. Hindsight's a perfect tyre, as they say.
Yeah every sl ive sold ive lost money on then regretted it, time to pick up another one!
    668K
