Orbea Wild M Team vs Strive:ON CF9 — same price, expert rider
magic_pie
I'm trying to decide between:
* 2025 Orbea Wild M Team: Factory suspension; pre-major update in 2025 and 2026; grip X2 in the front
* Strive:ON CF9 (newest Performance Elite front&back)
Same price.
Expert rider, 90kg with gear (athletic), prefers playful bikes and creative lines over ploughing through rocks. Mostly riding Finale Ligure.
I'm trying to decide between: 2025 Orbea Wild M Team vs Strive:ON CF9. Same price. Expert rider, 90kg with gear, prefers playful bikes and creative lines.
Right, two different philosophies, and the motor question is actually simpler than it looks: both run Bosch. The Wild M-Team uses the CX Gen 5 (100Nm after the May 2025 OTA), the Strive:ON has been updated with the CX at 120Nm as of the 2025 revision. Motor character is similar enough that it's not the deciding factor here.
The Wild M-Team — confirmed geometry from the database:
SizeReachStackHead AngleSeat AngleChainstayWheelbaseBB Drop
S435mm625mm63.5°77.5°448mm1228mm22mm
M455mm634mm63.5°77.5°448mm1252mm22mm
L480mm643mm63.5°77.5°448mm1282mm22mm
Factory suspension and a Grip X2 damper up front is a serious specification. The Wild is composed and confidence-inspiring — rewards aggression on rough ground but it is not the most playful or flicky bike at low speed.
The Strive:ON CF9 has a more aggressive, shorter-and-slacker geometry designed around generating front wheel pop and playfulness. The CF9 spec comes with Performance Elite suspension front and rear, which is a competent mid-tier Fox setup but sits below the Factory-level damper in the Wild M-Team. At the same price, that suspension gap is the real trade-off.
For Finale Ligure, 90kg, and a preference for playful and creative lines over ploughing: the Strive:ON is the stronger match. The geometry suits the place. The Wild is the better-suspended bike for the money, but if the choice is between a more capable damper and a more playful chassis, Finale rewards the chassis.
The caveat: at 90kg the Performance Elite dampers will work, but on the faster, rougher lines like Men's DH or Gobbo you may find yourself wanting more. A damper upgrade could follow. Factor that in.
What size are you looking at on both?
    Join 43,095
