Compare Pivot Shuttle AMP'd Pro X0 versus Mondraker ZENDIT RR S
Singletrackmind
San Diego, CA
Please compare the 2 bikes and include frame geometry information for a size large along with a list of complete component specifications. Also provide information on difference on battery and which particular area each bike shines, for example technical climbs and downhill runs.
Both bikes have full 29' capabilities, so please explain how each bike goes about flip chip and geometry adjustments and the impact to performance when not being run as a mullet.
Please compare the 2 bikes and include frame geometry information for a size large along with a list of complete component specifications. Also provide information on difference on battery and which particular area each bike shines, for example technical climbs and downhill runs. Both bikes have ful...
I have solid data on both. I have the Pivot size L reach (475mm) and HTA (63.7°), plus the Zendit reach for size L (460mm) and HTA (63.5°). Both run Avinox M2S motors. Let me write this up.
Right, two absolute weapons here, both running the Avinox M2S. Here's how they stack up. Geometry - Size Large (stock MX, standard flip chip position)
SpecPivot Shuttle AMP'd Pro X0Mondraker Zendit RR S
Reach475mm460mm
Head Angle63.7° (High)63.5° (Standard)
Seat Angle (eff.)76.5°77°
Chainstay443mm (all sizes)455mm (L/XL), 450mm (S-M/L)
Seat Tube - 460mm
Travel F/R160/150mm170/165mm
Wheels (stock)MX (29/27.5)MX (29/27.5)
In the size large, the Pivot has a 475-millimeter reach, 63.7° head tube angle, 443-millimeter chainstays, and a 76.5° seat tube angle. The Zendit L runs a 460mm reach with the size L, and
sizes S through M/L get a 450mm rear center, while L and XL frames bump up to 455mm for balanced weight distribution across the size range. Component Specs
ComponentShuttle AMP'd Pro X0Zendit RR S
ForkRockShox Zeb Ultimate 160mm, Charger 3.2Fox Podium 29 Float GRIP X2 Factory Kashima 170mm
ShockRockShox Super Deluxe UltimateFox Float X Factory Kashima 205x65mm
DrivetrainSRAM X0 Eagle AXS TransmissionSRAM X0 Eagle AXS Transmission
CranksPraxis Alloy 155mm, 34T - (36T chainring)
BrakesSRAM Maven Silver 4-pot, 200/200mm HS2SRAM Maven Silver 4-pot, 200/200mm
WheelsDT Swiss Hybrid HX1501DT Swiss HX 1700
TyresConti Kryptotal F 2.4 SuperSoft / R 2.6 SoftMaxxis Assegai 2.5 MaxxGrip EXO+ / DHR II 2.4 MaxxTerra DD
DropperOneUp V3 (210mm on L)Fox Transfer Factory 180mm
Bar/StemPhoenix Team Carbon 780mm / Enduro V2 40mmOnoff S9 1.0 Carbon 800mm / Onoff S9 30mm
Weight21.5kg (size L claimed)23.2kg (measured M/L)
Motor & Battery
Identical powertrain. Avinox M2S producing 130Nm of torque at the crank and 1,300 watts of peak power, with a Boost mode that pushes torque to 150Nm for up to 60 seconds.
Both run the integrated 800Wh battery. There's no functional difference in range or output between the two - same motor, same battery, same 508W fast charger. Whatever one does, the other does too in electrical terms.
Flip Chips & 29er Conversion - this is where they diverge The Pivot uses a single flip chip at the seatstay-rocker link.
Each frame gets a 63.7° head angle and 76.5° effective seat tube angle with the flip chip in high; drop to low and you shave half a degree off the angles while lowering the BB by 5mm.
It offers the ability to run either MX or dual-29" wheels, as well as a High and Low geometry flip chip position. Critically on the Pivot, the flip chip does BOTH jobs at once
Reach475mm460mm
Seat Tube-460mm
CranksPraxis Alloy 155mm, 34T- (36T chainring)
Motor & Battery
Think my request may have thrown you for a loop. Mondraker has a M/L frame option as well as a Large, my apologies.
It seems like your reach info on Mondraker needs to be revised.
Compare SRAM Maven Silver versus Maven Ultimate and DT Swiss Hybrid HX1501 versus DT Swiss HX 1700.
    670K
