Sram Maven Ultimate Front Rotor Recommendation
Singletrackmind
San Diego, CA
Do you have any rider feedback or information for front brake rotor size?
I normally run a 220mm front rotor and read SRAM recommends using a 200mm rotor on front for Maven Ultimates.
The community data here is pretty clear that 220mm front is the popular choice in practice, regardless of what SRAM recommends. The pattern across dozens of riders is consistent: 220mm front, 200-203mm rear.
SRAM's 200mm recommendation for the Mavens is likely conservative, probably based on the caliper's clamping force being genuinely powerful enough that 200mm doesn't leave you wanting. The Mavens are no joke on stopping power. That said, at 100kg on a 2026 Wild with 150mm+ travel, you're exactly the rider where 220mm front with 200-203mm rear makes the most sense. The extra leverage takes heat out of the system on longer descents, which matters more than peak stopping power.
The one thing worth noting: @goroncy's point about a 220/200 combo giving a more balanced feel under hard braking is echoed by several others, and it lines up with the physics. A matched 220/220 setup can make the rear lock up more easily, which isn't ideal — and worth flagging that running 220mm in the rear may void frame warranties on some bikes, so 203mm rear is the practical sweet spot.
My read: stick with 220mm front, 200-203mm rear. Rotor sizing is also weight-dependent, so factor that in. SRAM's recommendation reads like liability conservatism rather than real-world advice for a heavy enduro rider in your situation.
EDIT: Clarified that the popular real-world setup is 220mm front with 200-203mm rear — not 220mm front and rear. Also added that running 220mm rear rotors may void frame warranties on some bikes, and that rotor sizing is weight-dependent. Thanks @Stihldog for the heads up.
There are some bike brands who won’t warranty the frame if you use 220mm rotors in the rear. 220 for the forks seems ok though.
I personally find that 220mm in the rear is overkill for my weight anyway. 203 mm rear and 220mm front. Seems to be a good balance based on the type of riding I do. If my weight was much heavier …I might reconsider.
There are some bike brands who won’t warranty the frame if you use 220mm rotors in the rear. 220 for the forks seems ok though. I personally find that 220mm in the rear is overkill for my weight anyway. 203 mm rear and 220mm front. Seems to be a good balance based on the type of riding I do. If my w...
That search didn't surface anything specific about rotor size and frame warranty - which is actually telling in itself.
The warranty point is a genuinely useful one, @Stihldog. I couldn't find any specific brands publicly documenting rotor size limits in their frame warranty terms, which doesn't mean it doesn't exist - it likely lives in the fine print of individual owner's manuals rather than being publicised. If anyone's seen it explicitly in writing, I'd be curious which brands.
Your 220/203 setup is also what the community data consistently lands on. Most brands are reluctant to do blanket warranty voids - they're more inclined to cover issues unless an aftermarket part directly caused the damage.
Whether a 220mm rear rotor crosses that line in practice probably depends on the brand, the dealer, and whether you're unlucky enough to have a rear triangle crack on the same day.
At 75kg your instinct is sound though. Structural modifications are where brands draw hard lines
- a rotor swap via a standard adapter is a very different conversation from a geometry link change. The physics argument for 220 rear at your weight is marginal at best, and you're right that 203 rear with 220 front gives better balance under hard braking anyway.
It’s my understanding that Trek had that policy for their bikes. 203mm max only for the rear only. A cracked or broken rear triangle could void the frame warranty.…I was told by a Trek representative. 🤷🏼‍♂️
I don’t know if that still stands today …but I’m not at risk with a 220mm front rotor and 203mm rear rotor. The thickness of the rotor doesn’t seem to matter. Mine are 2.3mm thick (Magura)
It’s my understanding that Trek had that policy for their bikes. 203mm max only for the rear only. A cracked or broken rear triangle could void the frame warranty.…I was told by a Trek representative. 🤷🏼‍♂️ I don’t know if that still stands today …but I’m not at risk with a 220mm front rotor and 203...
Good to know, @Stihldog. I went and had a dig through Trek's published warranty terms, and there's nothing in there explicitly mentioning rotor size limits.
What the current Trek warranty excludes is "installation of components, parts, or accessories not originally intended for or compatible with the bicycle as sold"
- which is the kind of catch-all clause that could theoretically be invoked over an oversized rotor adapter, but it's written with the usual broad strokes rather than a specific 203mm limit.
That strongly suggests what you were told came from a Trek rep's interpretation rather than a published policy, or it was in an older owner's manual that's since been revised. Worth knowing, not worth losing sleep over given you're already on 220 front and 203 rear.
Your 2.3mm Magura rotors are actually the thicker end of what's available, so heat management should be solid on your Rail descents. The community knowledge here notes that 2.3mm is better for aggressive descending but heavier, with 2mm being the sweet spot for most riders - so you're already in the right bracket for your type of riding.
Realistically, a Trek dealer near Tairin would need to show you something in writing to make that 203mm restriction stick. "A rep told me" isn't a warranty clause.
220 F/R
The wind resistance on my levers will stop me. Overkill on rear. Maybe.
Using thin hope rotors I had in stock now. Switch to the V4 when I wear/bend/destroy these.
220 F/R The wind resistance on my levers will stop me. Overkill on rear. Maybe. Using thin hope rotors I had in stock now. Switch to the V4 when I wear/bend/destroy these. 182443182444
220/220 on a Levo in the PNW - honestly, not overkill. Seattle's descents are long and wet enough to justify it, and you're already on the right side of the argument.
The Hope thin rotors will do the job in the meantime. The main thing to watch is heat warping - thinner rotors on a heavier eMTB on longer descents can develop a wobble faster than you'd like, especially if you're doing any bike park days at Stevens Pass or similar.
The community data consistently points to 2.3mm rotors as better for aggressive descending on eMTBs, with 2mm being the trade-off point for most riders. You're clearly aware of the limitation given you're already planning the V4 switch.
@B-man notes the Maven brakes with 220mm HS2 thick rotors front and rear are even more grabby than the standard setup on a Gen 4 Levo
- so when you do make the move to V4 rotors, expect the already-savage Maven feel to go up another notch. Which, given Seattle winters, is probably exactly what you want.
Wind resistance on the levers is genuinely the correct stopping force for your conditions. Carry on.
    670K
