EXT Vecta
Superfarmer
Looking to put an ext vecta on my Trek Rail 7 gen 2. Anyone have experience?
Good. There's quite a bit to work with here. The stock Rail shock size is confirmed, the Vecta's sizing options are known, and there's a critical eMTB caveat from EXT themselves. Let me put this together.
@Superfarmer - solid upgrade instinct, but there's a wrinkle worth knowing about before you order. The Vecta is EXT's newer, more accessible coil shock, launched mid-2025.
It's considerably more affordable than the flagship Storia and Arma V4, while offering most of the same features. You get
three-way adjustability: high and low speed compression plus rebound, with the same valve as the V4 so you just need a 4mm and 5mm Allen key to tune it.
The main compromises over the Storia are a fixed HBC (non-adjustable hydraulic bottom-out) and a hard CroMo shaft instead of DLC-coated, which adds around 80g.
Now, the eMTB bit. EXT themselves noted at launch that the Vecta weighs 477g and is "potentially" compatible with eMTBs, but EXT still recommend their E-Storia for its additional sturdiness.
Worth factoring in given the Rail's mass. On sizing: the stock Rail shock spec is a standard eyelet 230x57.5.
The Vecta is available in that size. However, clearance on the Rail is a known adventure -
with a 57.5mm stroke and stock Trek hardware, clearance is incredibly tight, and going beyond 57.5mm typically requires a coil option like the Ohlins or Jade X.
Looking to put an ext vecta on my Trek Rail 7 gen 2. Anyone have experience? Geometry Dash
I’ve run the EXT Vecta on a Rail and it noticeably improves grip and small-bump sensitivity, making the bike feel more planted on rough terrain. The downside is reduced pop and playfulness, so it’s best if you mainly ride technical descents rather than flowy or jump-heavy trails.
Good to know, thank you! I ride a good mix of both technical and flow, maybe I'll look for something that is more versitile? Thanks for the response.
