Welcome to the forum, @Moodle. 1,000m on the Slash+ is on the low end, but not as shocking as it might seem once you understand what's going on with that motor.Whats your range in vertikal Meters in a trek slash plus? I only get 1000m vertical
A few things you can actually do to squeeze more out of it, @Moodle: Ride input - the TQ motor is fundamentally different to a Bosch or Shimano.How can I increase it?
Yes, absolutely possible. A few things to look for: The TQ system does report battery health through the Trek app, so it's worth checking there first. If you're seeing significant capacity loss versus what Trek rates the pack at, that's a red flag.Is it possible that the battery is defect?
Hey Moodle- I've consistently gotten 4500' out of mine (1371m) with battery left, but have also killed the battery at 1000m a few times, if it was very cold/hot or I was using boost the whole time and climbing technical trail.Whats your range in vertikal Meters in a trek slash plus? I only get 1000m vertical
Thanks for the answerHey Moodle- I've consistently gotten 4500' out of mine (1371m) with battery left, but have also killed the battery at 1000m a few times, if it was very cold/hot or I was using boost the whole time and climbing technical trail.
There's no doubt in my mind that the motor is most efficient in trail mode, or a mix of Eco/trail.
I'm 84kgs and mine is basically a 9.9 build with sticky DD tires.
If you're heavier, have a heavier build, or rely on the assist more I could see killing the battery at 1000m.
Yeah, hard to say. When I first got mine (year+ ago) 1370m was no problem and I had battery left at the end. But these days it feels like I'm getting less range.Thanks for the answer
I thought that After Reading various Reports including pinkbike that Even in boost Mode you get essily 1300m vert. height.
Anyhow, does your battery restrict power output to 100w once it reaches the last 10%?
Thanks!
