Levo Gen 4 Levo EVO Rumor Thread – Longer Travel Levo Coming?
I don’t think the mythical 600wh battery exists outside of the few that Spesh has to “show off” how light you can theoretically get the bike. My local Spesh dealer was saying its a supply chain issues with the cells or something along those lines and Spesh has no ETA when they’ll actually be available for purchase.
You make me feel very special... my Levo already has the 605w installed! It seems your distributor doesn't have up-to-date information...
All I know is he’s got a few on order for customers and Spesh can’t give him a firm ETA. I’ve actually not seen anyone with the battery but then again all my mates ditched Spesh, I’m the only one that still owns a Levo.
E-bike
Battery
840Wh battery
UI/Remote
Mastermind TCU, 2.2" high resolution screen, fully customizeable with Specialized app, works with Apple Find My
Motor
Specialized 3.1 Motor, 105Nm torque, 810W power
Charger
Specialized 4amp charger
Frameset
Seat Binder
Alloy, 38.6mm
Frame
Levo Evo FACT 11m carbon frame, 12x148mm dropouts, sealed cartridge bearing pivots, SRAM UDH compatible,
170mm rear travel, 29" front wheel/27.5" rear wheel, adjustable head tube angle, chainstay length, integrated SWAT storage
Suspension
Fork
All New SRAM FS ZEB Select, 29" 180mm, Linear XL spring, Delta RC damper, rebound adjust
Rear Shock
All New Vivid Select air, 230x62.5mm, Linear XL spring, RT damper w/climb switch, rebound adjust
Brakes
Rear Brake
SRAM Maven Bronze, 4-piston caliper, hydraulic disc, 200mm rotor
Front Brake
SRAM Maven Bronze, 4-piston caliper, hydraulic disc, 220mm rotor
Drivetrain
Cassette
SRAM 12-speed,10-52t
Chainrings
SRAM 34t T-Type chainring, 104 BCD, steel
Shift Levers
SRAM AXS Pod Controller w/discrete clamp
Chain
SRAM GX Eagle Transmission 12-Speed Flattop Chain
Crankset
SRAM S1000 Alloy crank, ISIS interface, 155mm length
Rear Derailleur
SRAM S1000 Eagle AXS
Wheels & tires
Front Tire
Butcher, GRID Gravity, T9 compound, TLR, 29x2.4"
Rear Tire
Cannibal GRID Gravity T9 TLR Downhill Tire 27.5x2.4"
Spokes
DT Swiss Elemental
Front Hub
Specialized alloy front hub disc, sealed cardridge bearings, 6-bolt, 15x110mm thru-axle, 32h
Rear Hub
Specialized alloy rear hub disc, sealed cartridge bearings, 6-Bolt, 12X148mm thru-axle, 28h, HG Steel Fhb
Rims
Specialized Alloy Rims
Inner Tubes
Standard, Presta Valve
Cockpit
Stem
Alloy Trail Stem, 35mm bar bore
Handlebars
Alloy handlebars, 35mm diameter, 8 degree back sweep, 6 degree up sweep, S1/S2: 780mm/30mm rise, S3-S6: 800mm/50mm rise
Saddle
Bridge Comp, Hollow Cr-mo rails 155/143
Grips
Specialized Trail Grips
SeatPost
Xfusion Manic, infinite adjustable, two bolt head, Remote SLR LE lever, 34.9, S2: 125mm, S3: 170mm, S4-S6: 190mm
Accessories
SWAT
SWAT Internal downtube storage
Weight
25.16 kg (55 lb, 7.5 oz)
Weight Size S4
Compliance Certification
As applicable, certified to UL 2849 (e-system) and/or UL 2271 (battery) by UL Solutions and/or SGS.
For information on lithium-ion battery standards and regulations in New York City, visit: [www.nyc.gov/fdny/batteries](https://www.nyc.gov/fdny/batteries)
Price?
Same as Levo 4 comp carbon
From one of the market leaders and (former?) technology leaders I'd expect something around 22 kg, like Unno Mith or Teewing Flux.
This whole Levo 4 platform is hopelessly outdated. At least they are trying.
Specialized should try to generate value or interest in the Levo 4 platform with better builds & prices until they can roll out the next gen that will hopefully be competitive.
The spec choices on some of these builds is awful (S1000 RD with Rockshox base level suspensions or Rhythm suspensions, come on!).
To be fair, though, the battery is very large, and the tires add significant weight, especially in this case.
Furthermore, the battery is replaceable, which, as it turns out, adds a lot of weight. It's strange that everyone is currently switching to permanently installed batteries and Specialized making them easily replaceable. Either way, don't compare apples and oranges, or at least, mention it. And no, I don't have a Levo 4 :)
Where do we find information on the builds?
The release date was yesterday the 14th. Spoke to my local shop who confirmed this and told me a little about the bikes, then apparently the embargo was pushed forward.
E-bike
Battery
840Wh battery
UI/Remote
Motor
Charger
Frameset
Seat Binder
Alloy, 38.6mm
Frame
Suspension
Fork
Rear Shock
Brakes
Rear Brake
Front Brake
Drivetrain
Cassette
Chainrings
Shift Levers
Chain
Crankset
Rear Derailleur
Wheels & tires
Front Tire
Rear Tire
Spokes
DT Swiss Elemental
Front Hub
Rear Hub
Rims
Inner Tubes
Cockpit
Stem
Handlebars
Saddle
Grips
SeatPost
Accessories
SWAT
Weight
Weight Size S4
Price?
New zeb but pictured with old one :unsure:
Here's the official info:
Cool
I’m a huge fan of HBO in suspension. Inspires confidence in drops, and mis aligned landings.
Good thing is I’m not sad, I’m not at all buttsore that I have my Levo and not this one. I’m still 100% satisfied, I’ll see if I’m sad next year! Time to ride….
This Levo Evo should be pretty fun in the right hands. It’s ready to go down fast.
Good luck new buyers!!!!
How light can you really make a 170/180mm enduro emtb? Similar Avinox bikes are 23-24kg.
My coil fork, coil shock, 170/150 mondraker crafty in size large (1320mm wheelbase) is 22.4kg, with the bosch cx and a 600wh battery. Add 0.8kg for an 800wh battery.
Cool
You should be able to buy the LT link (230x62.5mm shock needed) aftermarket so you can convert your Levo of you want. Just stick a longer airspring in your fork.
According to Sam’s Bikes video above; we will be able.
Changeable batteries for the win !
Get a second battery and you can actually use the bike in the higher power modes without any range anxiety.
Otherwise, what's the point in the higher power and torque?
    Join 43,233
