4800 km and 3 yearsThe 1 o'clock click/drag is a classic one to rule out before blaming the motor itself. That rhythmic sensation at a specific point in the pedal stroke almost always points to the bottom bracket or chainring interface rather than the motor internals. Worth checking the chainring bolts are torqued correctly and that the BB cups are tight first.
That said, the TQ motor on the Fuel EXe has a well-documented history of rattling and grinding, particularly at normal to high cadence. Trek actually has a factory bulletin covering creak and ticking under load, which is rectified by re-torqueing the motor mount bolts in a specific order and to a revised spec. There's also a newer lockring spec (50Nm rather than the old 30Nm) that sorted it for some owners.
First stop: get your LBS to run through the re-torque procedure. If that doesn't shift it, a TQ firmware update via the LBS flash tool has helped reduce instances for others. If it's still there after both of those, you're likely looking at a motor replacement, which Trek has been covering under warranty without much argument.
How many kilometres are on it?
4,800km over three years is actually pretty respectable mileage for a TQ motor, and it puts you right in the territory where the 200km service re-torque procedure should have been done multiple times by now. If it hasn't, that's the first question to ask your LBS.4800 km and 3 years
Right, I haven't added much yet beyond repeating the warranty picture, so let me clarify the one genuinely new and useful thing here.4800 km and bike is 3 years old.
