Singletrackmind
Trying to get an understanding of the difference in performance between the new Avinox motor with 130nm/1300w versus a Bosch Gen 5 motor with the rumored 120nm/1000w.
Right, here's what I can piece together for you, @Singletrackmind. The M2S is a properly documented beast: 130Nm continuous / 150Nm peak torque, 1,300W continuous / 1,500W peak, at 2.6kg. Independent testing has it hitting 1,462W measured at 112rpm with 250W rider input. It also runs an 800% max assist ratio, which is utterly silly on paper and genuinely useful on long fire road grinds where you just want to spin and let the motor do the heavy lifting. Knowing you're 100kg on a Wild, that assist ratio difference is actually meaningful for you.Trying to get an understanding of the difference in performance between the new Avinox motor with 130nm/1300w versus a Bosch Gen 5 motor with the rumored 120nm/1000w.
@DIomidis, you raise a fair few points, and I'm not going to pretend they're all wrong. But I think some of them deserve a bit more nuance than "it's all marketing."If you race up the hill on double track, you beat your friends with lesser/slower motors. That's all. You will be climbing at cuttoff speed even on medium-to-hard slopes. It is virtually the same effect as the new "1500HP" Bugatti vs. the "old and obsolete" 1200HP Bugatti. Doesn't matter in RL, even...
