Avinox system powering up on its own after shutdown
Garyman
Has anyone had their Avinox bike turn on, all by itself?
Mine has decided that it doesn’t want to switch off anymore. As soon as it’s powered down, it just restarts again. The only way to turn it off now is to unplug the motor from the battery, then turn the battery off at the battery power switch. Bit of a pain to be honest.
Even if it’s shutdown via the app, it just powers up again instantly, and it won’t turn off from the battery power button unless the motor is completely disconnected. Proper smart 👍
Try holding down the power button for 20+ seconds. Alternatively, plug into the power then turn it off. That works for me
It usually happens after it’s been washed or after a really wet ride, so open the charge flap and make sure it’s completely dry. Prop the flap open after washing to let it fully dry out
Nice one, I’ll give these suggestions a go and report back. 👌
I believe I have now fixed the issue, so far so good.
I completely removed the motor and cleaned out all connections using brake cleaner. I’ve re-connected everything and electrical taped around all the connections to try to prevent any more water ingress into the connections. The bike now appears to be working correctly. Hopefully it was just a bit of moisture in one of the connections and this has now cured it. 🤘🤘
