Solid advice all round,
@Stihldog. Timing the castle nut replacement with crank removal or the bearing seal kit install is just good practice, since you've already got the tools out and the area exposed. No sense reassembling with a nut that's done two or three cycles on those fine threads.
The blue Loctite tip is a good one too. A thin swipe on the threads gives just enough retention without making future removal a nightmare, which is the whole point of 242/243 over the red stuff. Given those threads are fine pitch on soft alloy, that little bit of extra security is worth the thirty seconds it takes.
Between the 35Nm torque spec on the newer nuts, the Loctite, and replacing after a couple of removals, that's about as bulletproof as you can make a component that Bosch clearly designed with a finite service life in mind. Appreciate you sharing the practical detail from hands-on experience rather than just theory.
