• Warning!!
    UK Pedelec Law
    Worldwide Laws
Can I use Specialized app once Levociraptor or Speedbox is installed?
Superdad
California
Hi:
First post here after months of lurking. ;)
Im 62, been riding all my life—and dirt since the early 80s—but with back issues and living up in the mountains I almost gave up. Until tried a friend’—and then bought—a Turbo Levo Comp Carbon (new on sale at my LBS for just $6K) a month ago.
It is magic (especially after putting on 16-deg. SQ Lab bars and dialing in my cockpit) but since my every other morning workout rides are a mix of road and dirt—with plenty of climbs and descents—I hit the dreaded 20mph assist turn-off and wow does the bike get heavy at the most inopportune moments!
I’ve read about the various available de-restrict systems—Speedbox, Pear Tune, and Levocirator (not interested in the planetary gear solutions as those completely goof the speedo and odometer)—and the Gen3 Levociraptor seems the ticket and is available and supported in the US.
So here is my question:
I know that BLEvo and the Levociraptor app add some control and functionality, but can I choose to stick with the Specialized app for day to day usage, or is that a total no-no resulting in Specialized instantly knowing I have a de-restrict hack plugged in?
The thing is, call me crazy, I really like the interface simplicity, and having the turning controls, ride tracking data, and mapping all integrated is rather nice and clean. Plus I already have a couple dozen rides logged and named and am not keen on loosing all that.
I know a lot of folks subscribe to other ride tracking apps or have Garmins and whatno, but I want to keep things simple for a while and just ride and log my rides without any cyber-fuss (I grew up in tech but like it less as I grow older… o_O).
So can some of you explain to me—in the context of Levocirapto—what apps I can and can’t use, and what apps are required for setting the limits (and maybe wheelsize changes if I do build up a set of 29/29 road/gravel wheels with narrower rims/tires—these 2.6” Butchers are not going to last long on the tarmac and the 30mm rims advise against less than 2.3” runber.)
Lastly, I might as well ask for current opinion—but don’t want to lose sight of the above Qs:
Will the Spesh dealer know that I had a de-restrict box installed? (Of course removing it before bringing the bike in for warranty service.)
The USA Levociraptor sales guy claims Spesh won’t know, yet he admitted that‘s just what he’d been told—and he didn’t have a clue about my software questions and told me to email their tech.
I know there are other threads here regarding the whole dealer detection/warranty issue. But I’ve yet to read real consensus on the matter.
Thanks all. Ride on.
—Alex C.
Im also trying to get a definitive answer to this question. I’m in Europe and the 25 km/h limit is really tiresome. Want to derestrict to 30 km/h for on road sections with a levociraptor, but I’m concerned about the warranty…👍
Alex, I can't answer all of your questions but can share my experience with Levociraptor and Spec Levo Turbo (Gen 3) with you. I'm in Australia (with the dreaded 25 kph block in place for ALL ebikes). I initially bought a levociraptor (gen 2) for my Spec Creo SL and it worked so well that I bought one for my Levo turbo as well. I continue to use the Spec app (originally Mission Control) and it records my rides and provides a range of other data as per normal - EXCEPT with the gen 2 levociraptor it records the distance at about half the actual distance covered. That's not an annoyance for me as I also record the rides with a Garmin Edge device which provides comprehensive data and correct speeds and distance (using GPS). I have recently upgraded my roadie (the Creo SL) to a Gen 3 levociraptor which means the spec app now records the true distance and speed. As for the LBS, I routinely remove the levociraptor devices before taking the bikes in for a service (well past warranty now anyway I would think) and nothing has been said to me at the LBS, EXCEPT one time I forgot to remove the levociraptor and they detected the change in wheel circumference ("the wheel circumference has been hacked"). Both bikes have had firmware updates without issue so my experience supports the LBS not knowing as long as you remove the device before taking it in. Of course using the gen 2 levociraptor the indicated odometer is not correct (but I know the correct readings from Strava and Garmin Connect) but that should be addressed by the Gen 3 levociraptor
    Join 43,159
