Deore 12 spd to Sram Transmission
Yotaismygame
PNW
Ordered e Ebike with a Deore 12spd on it and I already have a scram GX transmission I will swap on. Do I need a different front chain ring? I can't figure out if the T-type chainrings use the same narrow wide as any other 12spd chainring does.
T-type chain has bigger rollers. So chainring has deeper grooves. But I also use a normal 12s chainring on T-Type. But I use alloy.
As long as chain line is the same. Should be fine.
    675K
