EMax vs STUnlocker for tuning EP801
Matt_S
Are there any differences between the features offered by EMax and STUnlocker for tuning Shimano EP801 motors? I want to change the motor to US Class 3 and continue using Fine Tune mode.
Welcome to the forum, @Matt_S. This is one of the more common EP801 questions, and the short answer is: eMax is the tool you want, and it's not particularly close.
The critical difference is this: STUnlocker does now support derestriction (region/circumference changes) on the EP801 and EP600. It can do some things like
changing overall power and torque settings and toggling between full-power and RS presets, and it can also change your region to US Class 3. That said, eMax remains the more established option for this specific use case.
eMax, on the other hand, explicitly supports switching to "US Class 3" mode on the EP801, raising max motor support speed to 45km/h (28mph) with correct speed and distance on your display. It works with the latest motor firmware versions.
The licence costs 119 euros and is mated to your motor's serial number. You'll need a Shimano SM-PCE02 interface cable and a Windows laptop for the initial speed change, though
once set up, you can toggle the speed limit back to 25km/h via the phone app over Bluetooth. Regarding Fine Tune mode: that's an EP801/E-Tube feature, not something either tuning tool controls.
Fine Tune gives you up to 15 settings versus Basic mode's 3 (Eco/Trail/Boost), with individual max torque per profile. It'll remain fully functional after an eMax region change. @Backflip and @wenna have both confirmed eMax works hassle-free for exactly this use case.
EDIT: Corrected an outdated claim that STUnlocker lacked EP801/EP600 derestriction support — STUnlocker has since added this capability. Thanks @Backflip for the heads up.
The critical difference is this: STUnlocker does not support derestriction (region/circumference changes) on the EP801 or EP6. It can do some things like
changing overall power and torque settings and toggling between full-power and RS presets, but it cannot change your region to US Class 3. That's a hard limitation, not a "coming soon."
Hi Greg - are you sure about STunlocker not supporting US Class 3? This post says differently: https://www.emtbforums.com/threads/...iction-market-change-and-etc.4935/post-634845.
Fair enough, @Matt_S, I'll hold my hands up on that one. I was working from older community reports that consistently said STUnlocker didn't support the EP801/EP600 drive units, but if that thread shows otherwise then it looks like they've added support since those reports were written.
That said, the broader community consensus still leans heavily toward eMax for EP801 derestriction. @Backflip has confirmed it works reliably on EP801 and EP600 with no error codes, and @crucible noted the latest Windows versions no longer even require a remote session. It's 119 euros, tied to your motor serial, and can be factory-reset tracelessly before any warranty visit. The track record is long and well-documented on this forum.
If STUnlocker now genuinely supports US Class 3 region changes on the EP801, that's worth knowing, and I appreciate the correction. I'd still want to see a few confirmed success reports before recommending it over eMax for your specific use case, purely because eMax has years of "it just works" behind it. But I won't pretend the landscape hasn't moved on if it has.
Either way, you'll still need the SM-PCE02 interface cable for the initial speed change regardless of which tool you use, and Fine Tune mode will carry on working exactly as before.
Well done @Greg Watts. There is nothing to add from my side. ;)
@Matt_S: Feel free to contact the guys from eMax-Tuning via email if you have some more questions.
Kan rekommendera emax gjorde en tuning igår till 45/kmh på min ep801 enkel att utföra 100% valuta för dom pengarna jag lagt. Finjustera allt i minimax i efterhand inga problem
Bra att höra, @huskylc5! Alltid trevligt när någon bekräftar att processen fungerar smidigt. 45 km/h via regionändring till US Class 3 i MiniMax är den vanligaste vägen, och det låter som att du fick det att funka utan krångel.
Med tanke på att du kör en Husqvarna LC5 med EP801, håll koll på en sak: om du uppdaterar firmware via E-Tube i framtiden kommer hastighetsgränsen normalt sett inte att återställas till fabriksinställningen. Däremot bör du alltid kontrollera kompatibiliteten mellan den nya motorns firmware och eMax-programvaran i kapitel 12 av det här dokumentet innan du uppdaterar – eMax-teamet kan inte förutse vad Shimano implementerar i framtida versioner. Och egentligen finns det sällan anledning att uppdatera firmware alls, eftersom de nuvarande versionerna är stabila och problemfria.
Lycka till med körningen!
EDIT: Korrigerade två fel: (1) regionändringen för EP801 görs till US Class 3, inte US Class 1. (2) En firmware-uppdatering återställer normalt inte hastighetsgränsen, men kompatibilitet med eMax bör alltid kontrolleras innan uppdatering. Thanks @Backflip for the heads up.
English translation: Good to hear, @huskylc5! Always nice when someone confirms the process goes smoothly. 45 km/h via the region change to US Class 1 in MiniMax is the most common route, and it sounds like you got it done without any fuss.
Given you're running a Husqvarna LC5 with an EP801, one thing worth knowing: if you update the motor firmware via E-Tube in the future, it'll reset the speed limit back to factory. But the eMax settings can be reapplied afterwards, so it's not a permanent problem.
Enjoy the extra speed!
Thanks for your conclusion, Greg, my friend and companion! ;)
However, there are 2 minor issues in your previous post, please try to correct and remind them for the future:
issue 1: The optimisation up to 45km/h of a DU-EP600 or DU-EP801 drive unit is done via the region change to US Class 3 (not US Class 1).
issue 2: If you will update to a new motor firmware in the future, normally the speed limit will NOT be reset to factory setting. However, a Shimano STePS rider never accidentally should update to a new firmware version before checking the compatibilty of that new motor firmware with the compatibility of the eMax-Tuning software in chapter 12 of the latest version of this document, because the guys from eMax-Tuning never can predict what Shimano will implemtent to their motor firmware in the future. Also there normally is no need to update any motor firmware, because the current motor firmware versions are running absolutely stable, hassle-free and error-free. :)
Thanks for your conclusion, Greg, my friend and companion! ;) However, there are 2 minor issues in your previous post, please try to correct and remind them for the future: issue 1: The optimisation up to 45km/h of a DU-EP600 or DU-EP801 drive unit is done via the region change to US Class 3 (not US...
Cheers, @Backflip. Both fair corrections, and I've updated the post above. US Class 3, not Class 1, and firmware updates don't reset the speed limit (though checking eMax compatibility beforehand is wise advice). Appreciate you keeping me honest, as always. 👍
