Looking to buy a Cyctrac EM10?
Hey, looking to buy cyctrac em10
Right, the Cyctrac EM10. It's a direct-from-China full-suspension eMTB sold through Twitter Bike USA. Here's what the spec sheet actually looks like:
Carbon fibre frame with 140mm rear travel, paired with a choice of RS Air or RockShox Recon fork up front at 150mm travel. The motor choice is the interesting bit: you can spec it with the Bafang M510 (36V/250W, 95Nm) or go for the M560 (48V/500W, 130Nm).
Both are paired with a 720Wh Samsung battery, claiming 110-140km of assisted range depending on motor choice. Drivetrain is
Shimano M6100 12-speed, with a wireless Wheeltop option on higher variants. The honest context here: this is a budget Chinese direct-to-consumer bike. The Bafang motors are legitimate and used across plenty of the industry, but they're not in the same league as Bosch CX, EP801, or Avinox for refinement or dealer support. There's also no dealer network, so if something goes wrong, you're sorting it yourself or shipping it. We've seen
Chinese brand quality isn't automatically bad, but the question is whether [the brand] is a reputable one, which can often be tricky to answer.
Worth knowing: we have community reports that the EM10 and EM6 are readily available in some markets, one carbon, one alloy, so the carbon version does exist in the wild.
What's your budget, and where are you based? That'll tell me whether this is genuinely the best value option for you, or whether there are better alternatives in the same bracket.
