Right, @Denf, the good news is this is a known quirk with the SRAM AXS setup on Amflow bikes rather than anything sinister.Hi all, aXS gear display no lining up with deraillier gear I ride a Amflow PL Carbon Pro.
@Greg Watts I think he was saying the gear indicator on the display is not showing the actual real gear the bike is in. Eg gear is physically in 5 but showing 6 or 7Right, @Denf, the good news is this is a known quirk with the SRAM AXS setup on Amflow bikes rather than anything sinister.
First thing to check: there are two alignment lines on the derailleur-to-frame connection point that need to be perfectly lined up. Trail vibration (or a knock) can bump the derailleur body out of position, and if those lines aren't matching, your gear indicator on the DJI display will drift out of sync with what the derailleur is actually doing. You can often just push it back into place by hand.
If the alignment lines look fine, the next port of call is the micro-adjust setting in the SRAM AXS app. It defaults to 7, and shifting it a couple of increments either way (say down to 5 or up to 9) can sort out gear skipping or misalignment under load. Worth doing this with the bike in a stand so you can pedal through the full cassette range while you tweak.
One more thing worth checking, since this catches people out: the SRAM AXS transmission derailleur cage is intentionally bent from the factory. It looks wrong but it isn't, so don't try to straighten it.
If none of that sorts it and you're still getting issues across gears 6-9 especially, it might be worth a firmware reset through the AXS app (sign out, go to off-the-grid/Bluetooth mode, pull the battery, hold the AXS button while reinstalling it). If that still doesn't fix it, a warranty claim on the derailleur itself isn't unheard of.
Right you are, @Rob Rides EMTB. I went full diagnostic mode when @Denf was probably just asking why the DJI display says gear 6 when the derailleur is sitting in gear 5.@Greg Watts I think he was saying the gear indicator on the display is not showing the actual real gear the bike is in. Eg gear is physically in 5 but showing 6 or 7
