Please delete
Hi all, trek rail gen5
Welcome to the forum, @lotharmatthias. The Gen 5 Rail is a genuinely good bike. gfunkmc described it as a "weapon" and noted the frame looks significantly lighter than Gen 3/4, and having owned five of them back to back he's a reasonable authority on that.
Quick orientation on the range: the alloy models (Rail 5, 7, 8) run a 500Wh or 625Wh battery and start around £3,999 for the Rail 5. The Rail+ Gen 5 is the carbon, longer-travel version with an 800Wh battery and 160mm travel, starting around £6,000. Both use the Bosch CX Gen 5 motor at 100Nm. The Rail+ also has two flip chips, one for geometry and one for coil/air shock, though it's mullet-only as there's no clearance for a 29" rear.
One known quirk: there's a rattle from the battery lock mechanism under rough terrain. Annoying but widely reported and not a structural concern. Was there something specific you wanted to know? Sizing, specs, value comparisons? Happy to dig in.
