Hi all, ebikes avinox u other for enduro under 20 kilos I've got a Spacialized turbo Levo SL 2.
Welcome,
@gaviotaflotante. Good question, and there's actually quite a lot happening in the Avinox space right now. Your Levo SL 2 runs the SL 1.2 motor at 50Nm and 320W, and
it's still one of the lightest bikes in class, weighing around 18.48kg in real-world builds. The trade-off everyone knows: the small internal battery combined with the low-powered drive unit holds it back compared to more powerful alternatives.
If you want under 20kg
with full enduro grunt, the Avinox ecosystem is genuinely interesting. The DJI Avinox M1 delivers up to 120Nm and 1,000W peak, and at 2.52kg it's also the lightest full-power motor in its class.
The main enduro options:
Steppenwolf Tundra - we have this in the database. 170/160mm travel, 800Wh, £5,199. The most accessible Avinox enduro option currently available.
Atherton S.170E - Atherton's first eMTB, 170mm travel enduro, built around a 7075 aluminium frame with the Avinox M1 at its heart.
Three versions launching; £6,999 to £8,999, officially unveiled April 2026. This one's generating a lot of forum noise, as you'd expect.
Commencal Meta Power SX Avinox - 160mm travel enduro with alloy frame and 800Wh battery, mullet wheels.
Caveat: at just under 24kg in size L, it's not exactly a featherweight - so that rules it out for your sub-20kg brief.
