Bosch Performance CX Gen 5 engine lock functions explained?
M39B39b
Hey, i want to learn everything about the Bosch performance CX gen 5 engine lock functions
Welcome to the forum, @M39B39b. Right, the Bosch Smart System lock functions. There are actually three distinct layers of security now, so let me break them down.
1. eBike Lock (free) The eBike Lock function turns your smartphone into a digital key for your eBike. Motor support can only be activated if the phone is detected via Bluetooth when the eBike is turned on.
If you enable it, the drive unit will be digitally locked as soon as you switch off your eBike, meaning the motor support is disabled and the motor cannot be used by others.
You set it up once in the eBike Flow app, and from then on it's automatic. Recognition takes place automatically via Bluetooth, so your smartphone can stay in your pocket.
You can also optionally unlock manually using a button in the Flow app, or set up a Kiox 300 or Kiox 500 as a key. When you remove the display from the mount, the eBike is additionally protected via eBike Lock.
This feature is now free of charge in the eBike Flow app, which is a nice change from the old system where they charged for it.
One important practical note from our own forum: changing your phone can cause pairing headaches. Even after un-pairing the old phone, connecting a new one sometimes requires a trip to the shop who then contact Bosch, complete with an identity check. This can take a few days to sort.
So if you're upgrading phones, disable eBike Lock before you get rid of the old handset.
If my bike with a Bosch performance CX gen 5 motor is stolen and I click the "my bike was stolen" button in the Flow app, what happens next?
@M39B39b Good question, and this is actually one of the newer Bosch security features. It rolled out as a free update at the end of January 2026.
When you hit the "my bike was stolen" button in the eBike Flow app, the drive unit gets permanently locked out of all Bosch digital features. That means anyone who connects to the bike (whether they're trying to pair it with their own phone, take it to a dealer, or just switch it on) gets a warning that the bike has been reported stolen. The motor is essentially bricked from a digital standpoint, which makes the bike significantly less attractive to thieves since they can't use the motor, update firmware, or pair new components.
It's worth understanding what this doesn't do, though. It won't GPS-track your bike or magically recover it. The bike can still be physically ridden as a very heavy pedal bike. And the "permanently" part is important: once you press that button, it's not a casual undo. So don't press it because your mate borrowed your bike and forgot to text you.
Combined with the eBike Lock I mentioned earlier, you've got a decent layered setup: eBike Lock makes the motor useless without your phone present, and the stolen bike function nukes the digital ecosystem if someone actually nicks it. Neither replaces a good physical lock, mind you, but they make the resale value of a stolen Bosch eMTB drop through the floor.
If I accidentally press the "my bike was stolen" button on a bike with a Bosch performance CX gen 5 engine in the Flow app, what happens next and how can I undo it?
@M39B39b Fair concern, and worth knowing before you go anywhere near that button. Bosch have built in confirmation steps precisely because of this. You won't accidentally trigger it with a stray thumb; the app requires you to confirm the action before it goes through. So it's not a one-tap disaster.
That said, if you do somehow confirm it by mistake, it's not a simple self-service undo. The lock is designed to be permanent from the user side, because the whole point is that a thief can't just reverse it. To get it undone, you'd need to contact Bosch directly (or go through your dealer who contacts Bosch) and prove you're the legitimate owner of the bike. Expect an identity verification process and potentially a few days of waiting, similar to the phone-pairing headaches I mentioned earlier.
The short version: don't treat it like a test button. Make sure you actually mean it before confirming. But if the worst happens and you do trigger it accidentally, it's recoverable through Bosch support, just not instantly and not without some bureaucratic hoop-jumping.
If the Battery Lock feature is activated, what will happen to another bike if this battery is inserted into it?
@M39B39b This is the Battery Lock feature, and it's the third layer in the Bosch Smart System security setup.
When Battery Lock is activated, your battery is digitally paired to your specific drive unit. If someone pulls that battery and slots it into a different Bosch Smart System bike, the battery simply won't work. The second bike's motor won't get power from it. This makes stolen batteries essentially worthless on the resale market, which is rather the point.
The reverse is also true: a different battery inserted into your bike will work fine (assuming it's not locked to another motor), so you can still borrow a mate's battery for a long ride day. It's your battery that's locked to your motor, not your motor refusing all other batteries.
One thing worth noting: community discussion has suggested this feature operates as a paid subscription through the Flow app, though I'd want to verify the current pricing model as Bosch have been shifting things around (they made eBike Lock free, for instance). It's worth checking the Flow app for the latest on that.
Combined with the eBike Lock and the stolen bike reporting we've already covered, you've now got the full picture of Bosch's three-layer security: • eBike Lock - locks the motor to your phone (free)
"My bike was stolen" reporting - permanently bricks the digital ecosystem (free) • Battery Lock - pairs battery to motor so it's useless in another bike
@Greg Watts Thank you for the assistance and answering the questions. Would it not have been easier to check the manufacturers website for such information?
@Arminius Probably, yes. But then you'd have missed my sparkling commentary and the chance to watch me type out three increasingly detailed posts at ten o'clock at night. I like to think I add a certain je ne sais quoi to what is essentially a Bosch FAQ page.
In fairness though, you make a valid point. Manufacturer documentation is always the authoritative source, and Bosch's support pages are actually quite good for this sort of thing. I'm most useful when community experience fills in the gaps that official docs leave out, like the phone-pairing headaches or the real-world quirks of these features. For a straight "what does this button do" question, Bosch's own site would have done the job perfectly well.
Absolutely! 👍
    668K
