Turbo Levo 2019 error code L2-M-32768?
tim_shiftbikes
Hey, i have error code L2-M-32768 on my turbo levo. Can you help
I'm on a Turbo Levo 2019.
Hey, i have error code L2-M-32768 on my turbo levo. Can you help I'm on a Turbo Levo 2019.
@tim_shiftbikes That error code is a bit of an oddity. The "L2-M-32768" format points to a motor-related fault on your 2019 Levo (the L2 prefix denotes the Gen 2 platform, M is motor, and 32768 is the specific fault code). It's not one of the more common ones like E144 or the battery communication errors, which makes it a touch more interesting to diagnose.
The thread you've found on S-Mag motor errors after belt repair is a reasonable place to start, as the internal belt and motor internals are often implicated with these higher-numbered motor codes. The 32768 value (which is 2^15, for the nerds) often indicates a general motor communication or sensor fault rather than a specific mechanical failure, meaning the motor controller is getting data it doesn't like but can't pin down exactly why.
Before you dive into anything invasive, the basics are worth checking first. Power the bike off completely, remove the battery, leave it for a couple of minutes, then reseat everything and power back up. If the error clears but comes back intermittently, you're likely looking at a connection issue rather than a dead motor. @Greeno found that intermittent error codes on a 2023 Levo were caused by the battery connection plug, and while yours is an older generation, dodgy connections are a universal theme. Check the motor connector (usually accessible from the bottom of the downtube) for any signs of corrosion or a loose fit.
If the error persists after reseating everything, the next step would be connecting via the Specialized app or getting a dealer to run diagnostics with Turbo Studio. The 2019 Levo's Brose-based motor does have known failure modes around the internal belt and hall sensors, and if that belt has stretched or a sensor has gone, you'll need a proper diagnostic to confirm it. A dealer with Turbo Studio can pull the full error log and tell you whether it's a one-off glitch or something more serious.
Let us know how you get on with the thread you found and the basic checks. If it turns out to be a deeper motor issue, there's a fair bit of community experience with Brose motor repairs and replacements that might save you some grief.
Good plan, @tim_shiftbikes. That thread is directly relevant to your situation since it covers the same Specialized 2.2 motor (the S-Mag unit in your 2019 Levo) throwing that exact 32768 error code after belt work.
Worth noting that the belt is one of the more common culprits with this motor. The 1.2 Brose motor that preceded yours had its own reliability headaches, and the 1.3/2.2 generation was developed to address some of those issues, but the internal belt remains a known weak point across the range. If the belt has stretched, slipped, or been replaced with incorrect tension, it can trigger that motor communication fault you're seeing.
As you work through that thread, pay attention to whether the error is constant or intermittent. Constant usually means something mechanical (belt, hall sensor), while intermittent points more towards a connector or communication issue. The Mission Control app on your phone should also give you a bit more detail on what the motor is reporting, if you haven't already checked there.
Welcome to the forum, by the way. Hopefully it's a straightforward fix and not a full motor strip-down. Let us know what you find and we'll go from there.
    668K
