I see refernce to Base, Bronze, Silver, Ultimate (was Gold missed out?). But I also see refernce to A1 B1 and so forth.
Is there a Rosetta stone for Sram brakes?
@steve_sordy You're not alone in finding SRAM's naming a bit labyrinthine. Here's the Rosetta stone, such as it is. The tier system applies across SRAM's current brake families (Maven, Motive, and the older Code Stealth).I see refernce to Base, Bronze, Silver, Ultimate (was Gold missed out?). But I also see refernce to A1 B1 and so forth. Is there a Rosetta stone for Sram brakes?
@steve_sordy The B1 launched roughly a week ago, so we're talking very late February/early March 2026.When was the B1 generation launched? Is it likley to be on 2025 bikes?
@steve_sordy You've spotted the right wrinkle. The upgrade kit gives you the lighter lever feel, but it doesn't give you a true B1 experience, because the caliper stays put.I think that's a lot of money for a smoother power delivery and a near halving of the lever breakaway force! I note that as the upgrade is a dry one that it cannot involve the pistons. You said that the B1 comes with four 18mm pistons instead of a mismatched pair - "to balance out the higher leverag...
SRAM's intention with the B1 package as a whole is that the new lever/cam and the new caliper cancel each other out to deliver equal peak power to the A1. Run the B1 lever kit on your A1 caliper, though, and you end up with about 9% more power than stock, plus a slightly longer free stroke before bite.
Because the A1 caliper retains its larger pistons, fitting the gold B1 SwingLink to an A1 system actually produces the most powerful Maven configuration possible.
So "upgraded A1" is arguably a different beast entirely, not a B1 facsimile, but a B1 lever mated to an A1 hydraulic ratio. More power, lighter initial pull, slightly more deadband. Whether that's better or worse depends on what you're after.
When combining the older calipers with the new cams, you'll need to move the lever a little further before the pistons engage. One reviewer swapped in the B1 cams to a set of original Mavens and immediately noticed that increased deadband, along with a much lighter lever feel. Not the end of the world, but it's there.
As for the price gripe, that's entirely fair. It probably wasn't an ideal strategy to release the A1 with such heavy initial lever resistance, at least not in terms of PR, but the vast majority of riders got along with them perfectly well. For most people, there was no Maven problem.
The upgrade kit exists mainly for those who found the A1 feel genuinely fatiguing on long descents. If your Mavens never bothered you, the kit is a solution to a problem you don't have.
@steve_sordy Glad it landed. Genuinely one of the more interesting brake deep-dives I've fielded in a while - SRAM managed to make a good brake complicated, which takes a certain kind of effort.
Not up-speccing the Merida. Just trying to understand the Santa Cruz Vala 90 that I am on the point of buying.@steve_sordy Glad it landed. Genuinely one of the more interesting brake deep-dives I've fielded in a while - SRAM managed to make a good brake complicated, which takes a certain kind of effort.
Tag me again if the Maven question resurfaces when you're actually speccing that Merida.
