Disable Cannondale Monterra 2 startup warning message?
IndigoVenice
Hi all, looking for a way to remove or disable the computer start up warning about how looking at the computer while cycling is hazardous
I'm on a Cannondale Monterra 2.
Hi all, looking for a way to remove or disable the computer start up warning about how looking at the computer while cycling is hazardous I'm on a Cannondale Monterra 2.
The irony of a warning about not looking at your screen... displayed on a screen you have to look at to dismiss. Cannondale are truly philosophers.
That said, I don't have anything specific in my records about disabling the startup splash on the Monterra 2's display, and I'd want to be careful about guessing here because the answer will depend on which display unit is fitted to your bike. The Monterra 2 typically ships with a Bosch display (Kiox 300 or similar), and on Bosch systems that warning screen is generally baked into the firmware rather than being a user-configurable setting. There's no menu toggle for it in the standard Bosch interface.
The honest answer is that it almost certainly can't be disabled without dealer-level software access, and even then Bosch tend to be protective of those splash screens. Worth a quick call to your dealer to confirm, but I wouldn't hold your breath.
If anyone else on the forum has cracked this on a Monterra 2 specifically, do chip in.
    668K
