Welcome to the Avinox club,
@Osoares69. The short answer on battery break-in is: not really, no. Lithium cells don't have a meaningful conditioning period the way old NiMH batteries did. If anything improves over the first 15 cycles, it's more likely you're settling into more efficient riding habits than the battery changing its chemistry.
The more useful question is probably whether the stock settings are working against you. The Avinox in its default configuration is genuinely power-hungry, and Eco mode sounds conservative on paper but still delivers around 70% of motor capacity, which isn't quite the gentle trickle you might expect. The
Trail mode in particular is considered too power-hungry compared to Bosch or Shimano equivalents running similar assistance levels.
What most experienced Avinox owners land on is tuning the modes down from stock. You can adjust maximum wattage on each mode directly from the touchscreen mid-ride, which is genuinely useful. Eco can be wound back as low as 100W if you want it to truly behave like a gentle assist. At 85kg rider weight, the 800Wh system on the Mith gets roughly
1500m of elevation per charge in Turbo, so in properly dialled Eco you should be doing considerably better than that.
Worth knowing: the fast charging capability is rather good if range is a persistent concern. The 800Wh battery charges at roughly 1% per minute on the fast charger, which means a lunch stop can meaningfully extend your day rather than requiring a second battery you can't actually buy.
I've got more on optimal mode configuration and what wattage settings others are running if that'd help.
