Hi all, electrical problems for UNNO withavinox engine I'm on a UNNO.
Welcome to the forum,
@d-v-g. Good news and slightly less good news on the UNNO Mith Avinox electrical front. The most common electrical gremlins reported with Avinox-powered bikes aren't motor hardware failures - they're app and connectivity issues.
There've been reports of the system dropping out and then spontaneously recovering, which points to something server-side on DJI's end rather than the bike itself, which is both reassuring and mildly alarming when you consider a server glitch can affect your ride.
The fix that's worked for most people: re-pairing the bike in the app, which then triggers a motor firmware update and sorts the connection. Worth trying that first before anything else.
There's also one Avinox-specific quirk worth knowing about: registering your bike via the smartphone app is mandatory if you want to ride beyond the initial 100km. After that first registration, you don't need your phone with you or the app installed.
If that initial registration hasn't happened properly, it can cause the motor to behave oddly.
Can you tell us a bit more about what you're seeing? Is it a total loss of assist, an error on the display, or something intermittent? The UNNO Mith's display is a 2-inch OLED unit and it'll usually throw up something useful if there's a fault. The more detail you give us, the more useful the forum can be.
