My 2022 Marin Alpine Trail E2 with the Shimano EP8 motor needs a new chainring, but I can't seem to find one in stock. The correct one is apparently a Steps SM-CRE80 eBike Chainring with 104bcd and 50mm chainline. Can you confirm that I'm looking for the correct part for this bike and motor, and tha...
@mxh, right, let's get this sorted for you. You're on the right track with the SM-CRE80. The Shimano STEPS SM-CRE80 is indeed the correct chainring series for the EP8 motor. It uses the 104 BCD bolt pattern and the 50mm chainline is standard for Shimano's eMTB systems on the E8000/EP8 platform. Your 2022 Alpine Trail E2 should be running 12-speed, so you'd want the SM-CRE80-12 variant specifically (the -12 suffix denotes the 12-speed compatible tooth profile with the narrower/wider pattern to match).
Now, 36T is a slightly awkward size in the Shimano OEM range. Shimano typically offer the SM-CRE80 in 34T and 38T. A 36T isn't a standard Shimano offering for this chainring, so if you've been running a 36T it may have been an aftermarket ring from the start, or Marin specced an unusual option. Worth having a quick look at what's actually on the bike before ordering.
For aftermarket alternatives on 104 BCD with eMTB-appropriate chainline, you've got a few options. The Praxis Works E-Ring Wave is a solid steel option that works on 104 BCD cranks and comes in 34T.
@jxj ran a SNAIL 104 BCD 36T chainring on their Levo setup and found it
perfectly functional at a fraction of the price of branded alternatives, about $14 USD. That one does come in 36T, which is what you're after. You just need to make sure any aftermarket ring has the correct offset to maintain that 50mm chainline, as some generic 104 BCD rings are designed for standard cranks and sit at a different offset.
SRAM also make a 104 BCD chainring with an integrated bash guard for their eBike groupset, which
@doochenozzle mentioned is a
clip-on design. That could be worth a look given you've also been hunting for a chain guide with bash guard for the EP8, which would kill two birds with one ring.
Being in Australia, Bike-Discount.de in Germany might be your best bet for the genuine Shimano part if local stock is dry. They've been known to carry the SM-CRE80-12 in 34T at reasonable prices with international shipping. Otherwise, the SNAIL ring off AliExpress is the budget play and gets the job done. I'd just double-check the offset measurement before committing to anything aftermarket.
