Fork upgrade
Dunabunk
North East
Hi Guys. so i want to upgrade my forks from rochshox 35 gold to fox 36 performance, will these go straight onto my trek exe 9.5. both forks have tapered headset with
1-1/8" top, 1.5" bottom bearing configuration (often referred to as IS41/IS52), or will i need to change my crown race?
Thank you for helping
If new the Fox forks will come without a crown race. If you're careful you can remove the crown race from the Rockshox forks which I think will fit straight onto your new Fox forks.
I stand to be corrected because I've only done this ^^^ with Rockshox forks ...
If new the Fox forks will come without a crown race. If you're careful you can remove the crown race from the Rockshox forks which will fit straight onto your new Fox forks.
hi. thanks for your reply, that will definitely helps, forks are brand new but was taken off a amflow bike, im going to buy them. your help is appreciated thanks
Get a Manitou Mezzer if Hayes ever gets it's thumbs out of its ass and restocks the inventory.
You only need to swap the crown race from the 35 to the Fox. IF the 35 has the big spacers, the wheel may not fit without new ones. That is pretty rare these days, but it freaks people out.
    668K
