mxjames171
Hi All,
I am looking to find out if anyone has had a similar problem that I am experiencing on my E Bike. I have a Polygon N8e with a shimano EP801 motor.
The issue is that the motor will just turn off mid ride. Usually after about 30min - 1 hour. Battery has been anywhere from 90%-20% when this occurs. I am unable to power the bike back up. Screen remains black and motor will not turn on. When I go back home and plug the bike into the charger, even for only 1 minute, then unplug it, the bike will turn back on. I can then go ride it, and will usually last another 30 min before doing the same thing.
It's just been at the shop for this issue. They had carried out a number of recommendations from Shimano, including replacing the head unit screen on the bar, cleaning connections, re-aligning the battery harness (i think this is what they said). I got it back last night, took it out for a ride, and same thing happened again. So it's going back to the shop. But I am curious if anyone has had a similar issue and what was done to fix it if so.
Thanks,
Thanks,
