Amflow Pro Water Bottle
jsrice1129
Has anyone found a decent water bottle that fits with the Amflow Pro? The clearance is so small that none of my normal bottles will fit. Usually I ride with a hip pack but sometimes I like to ride light and would appreciate being able to use the water bottle cage.
*Update*
In case anyone searches this again, I got the Fidlock mount and it works well with the 600ML bottle size. You have to flip the mount and bottle holder as mentioned by others. At 600ML the bottle is very very snug, but I haven't noticed any issues with rubbing or getting knocked off. I might go with a slightly smaller bottle next time, but overall this is the way.
I solved this with a Wolf Tooth B-rad mounting base and a side entry cage. I mounted base as low as it will go without touching the frame. The base moves the cage down far enough to get a regular 20oz bottle in. I don't think a 24 will fit. My frame is a Large. The cage I used is a BRKURLEG Ultra-Light Carbon Fiber Water Bottle Cage. The Arundel is great- I have one on my analog bike- but just too expensive. So far it's been fine but I only have a few rides on it.
On a large PL but with a shock with a piggy back. Fidlock with the frame mount fitted backwards and the mount on the bottle swapped around to get a decent sized bottle in.
Agree, use Fidlock bottle and swap mount upside down on both bottle and the mount. No problem with clearance even on Medium frame
I run the fidlock 590ml on my large with storia v4. Flip both mounts for more room and keeping it right hand release. The bottom of the bottle does rub the frame a little bit. I honestly don’t care but I can see some people not liking the little mark it’s making.
The heck with water bottles, how is everyone running RockShox forks? Does the Zeb actually fit the large? The Lyrik doesn't even come close to fitting my medium.
Yes Zeb fits large. No issue at all.
    668K
