• Warning!!
    UK Pedelec Law
    Worldwide Laws
Bosch Smart System Derestrict - Long-term Success?
TrekPwrfly
United Kingdom
Hi everyone,
I've got a Bosch Performance Line CX (with Smart System) with drive unit software version 12.13.0 (have not updated since purchasing the bike). I installed a SpeedBox 1.1 a couple of weeks ago and had a 524001 Speed Manipulation Detected error after ~100kms. I was unable to clear it by riding for 90+ mins, so resorted to having a sympathetic dealer clear the error for me. Here are the exact details of the rides I did between fitting the SpeedBox 1.1, and the error occurring:
Journey 1 = 18mls, mix of eMTB and Turbo, generally riding at 35km/h
Journey 2 = 18mls, Turbo, generally riding at 35km/h
Journey 3 = 18mls, Turbo, generally riding at 35km/h
Journey 4 = 18mls, Turbo, generally riding at 35km/h
Journey 5 = Error occurred after 0.1mile
As you can see I set the max speed at 35km/h as per SpeedBox advice. On each occasion I let the countdown timer run at the end of the ride. Before I reinstall the SpeedBox 1.1, I want to see if there are other riders with a Bosch Smart System, with the same software version and the same SpeedBox product (or a different tuning device) that have successfully avoided an error for longer than me. If so, I'd be interested in what steps you are taking, or how your rides vary from mine.
Thanks!
My gen3 Rail has run from new derestricted with a speed box and always in turbo so I bought a new Rail with the smart system last year, same issues as you. Local bosch service centre seeing nothing but issues too. I took the hit and sold the bike and upgraded the old one. Won’t be buying another bosch, the smart one was my fourth. Dunno what next one will be
Do you mind if I ask a few more details...
What max speed did you set? How many miles did you do before you got the error? Were you mainly riding in Turbo mode? Did you have GPS switched off on your phone? (Just trying to build up a picture of how the smart system might be detecting the tuning device).
Tried max speed at several levels, always in turbo. Had app connected after first time then removed and deleted it after for the following attempts. The shop I used reset it 4 times, over a month they had all the chips they’d sold come back. Seems an update at the time had done this, shop also suspected the app is used for speed detection too. As I said this was my fourth bosch powered bike but I’m done with them now.
the service loaded the engine software for the American market and now I have a power steering limit of 32km/h, which isn't much, but it drives much better.
Hi everyone,
Thanks!
Is your sensor a rim magnetic if so the SpeedBox 1.1 and 1.1B will not work
Only a thought
I have the SpeedBox 1.0B and happened to me one time. To avoid it again I didn’t use the flow app while ridding. I disconnected the bluetooth connection on the flow app.
After that i have rode approximately 500 miles.
Hi everyone,
Thanks!
Make sure you dont use Flow app at the same time. In fact disconnect the Bosch Bluetooth from phone. It will detect your real speed via GPS.
I still use the flow app so I can adjust settings, I just dont let it have GPS access. Volspeed V2 and about a year/1000 miles of use so far and no errors. I do have it limited to 34kph though as they say it gets easier to detect over 35
That's one way to do it |!
Hi everyone,
Thanks!
I had the same setup. The key thing is never use Flow app that connects the phone to the motor. They can detect how fast you are going by the GPS of the phone. Don't even install Flow because it could run in the background.
    Join 43,119
