Levo Gen 3 My remote stopped working on my Gen 3
KTMJack
Oakley Ca.
Do these have problems the rubber not open to dirt or moisture It just stopped working no buttons work
I don't see any damage to the wire and I guess I have to see if it's still plugged in And were does it plug in
The Gen 3 Remote is "stupid" 5- wire foil taster remote with no logics inside. If no any button is responding then there are two possible issues possible:
a) the violett cable is broken ( comon line for all buttons)
b) the mastermind control unit has failure.
normally only one button (-) corrodes away and start to not respond. The remote is not completely sealed and high pressure water can easily flood it, Just rain should be not an issue.
You can remove Mastermind and re-plug the remote. If afterward nothing works, then you need to look deeper.
I took the mastermind out and it's plugged in I did not see any damage to it .
I pushed the + button and it went orange and had a speed setting at 50% I pushed it again 60%
I pushed it till it was at 100% That is the only thing it will do . I'm not sure what it did .
Is this a mastermind thing or do I just replace the remote
That is micro tune modus. Maybe only + button survived. Guess you will need to visit your local S shop and ask for check.
    Join 43,288
