Hello… Levo gen 3, suddenly has run on?
jeffers-emtbb
West Malling
Motor giving occasional 2 meter run on all of a sudden. Issue pending perhaps?
it’s Due a service this winter as over 2 years old and around 2500 miles on it.
Failing torque sensor. Time for a motor rebuild.
Check your magnet pick up on your disk , I had this problem on my Kenevo. The places I ride have a lot of free iron in the soil and I found a lot of iron filings stuck to the mag pickup, once I cleaned it it was fine. Also go into your app, look at the overrun settings, one of my riding buddies changed his overrun from turbo to trail by accident while changing his power settings .
Thanks, magnet is clean. And will check overrun, however as it happens inconsistently, I don’t believe it’s that. Ran a diagnosis on the app to see if that throws up anything.
High Rock Ruti
"Time for a motor rebuild/replacement"
Is the correct answer, congratulations 2500 miles is a long life for a Brose motor.
Sorry don't mean to be mean, just had a long history of Brose failures 10 motors across 4 bikes. Last motor rebuilt in Tennessee by the state side bearing man, good folks, short money
Warm Regards Ruti
High Rock Ruti
Warm Regards Ruti
Mine is in the shop getting replaced right now. Same issue. 5 motors on 2 bikes=same as Ruti.
Same but different ??? I had a weird one two days ago spinning chain backwards with alllan key in crank and motor switches on.
High Rock Ruti
Warm Regards Ruti
Thanks, it’s gone into the e bike motor centre in the UK. Their over the phone diagnostics was clutch bearings starting to go. They will re build and improve it. 👍
Ever time I intended putting a motor to them for repair my dealer gave me a better offer. I will get one to there one day maybe. Good luck 👍
