km - batt. %
etcho
Slovenia
Hello.
I have a question regarding the Avinox display. In the upper right corner, it shows the battery percentage. However, I’ve noticed several times that it displays the estimated range (km) instead of the battery percentage. I’m wondering if I accidentally activated this mode myself, or if there’s another reason why this is shown? I would like it to always display only the battery percentage.
Hello.
touch on the display ,-)
I set the bottom right to battery %, I really shouldn't have to take my hands off the handlebars and touch the screen to see the battery % when it decides to show guestimate mode instead.
A quick swap between screens (using the handlebar remote if you still have it on the bike) also does the trick.
I tried that, but after a few moments it showed km again. Amflow support advised me the following: "If you would like the upper right corner to show the battery percentage instead, you can simply tap the corresponding data on the central display to switch between display modes.", as @daytrader already mentioned.
It should only change each time you tap the upper right corner.
With each tap on the screen it will alternate between %- km-%-km.
It should stay on what the last tap of the upper right corner left it on.
I sometimes find mine on the guessometer when I have been cleaning the screen and accidentally ran my finger over the % number in the upper right corner. A quick dab on the km figure in the upper right corner will then put it back to %.
This also works if you have created a custom screen with the battery%/km (dual field) positioned elsewhere.
Tesla cars also have a dual field display for %/ km range which switches when you tap the number. You don't have to change screens or go in to the setup to change this.
