2025 Orbea Wild to Mullet
rickdavid
Hi, I have the 2025 Orbea Wild M20 w 29' wheels and I would like to switch it to a Mullet 27.5 rear wheel. I'm going to install the magnet in the 27.5 rim's valve. Is there anything else that should be done in order for the bike to work properly?
Update, sensor read without change the link.
Mullet link is about 1cm longer on top, should be to keep clearance.
Diameter of the tire can be adjusted from the Kiox 400C.
I don’t understand why I have to take it to the Orbea Dealer ? Software calculations for power delivery?
The wheel circumference setting in the Kiox and the Flow app only affects the displayed speed and the calculated distance. This setting does not impact the motor cut-off speed. This is an internal setting that can only be changed with service software. That's why you have to take it to the dealer after changing the wheel size. It would be nice if the setting would be same to allow for some cut-off speed user adjustment, but it's obvious why Bosch designed it this way.
View attachment 169589 View attachment 169590
Where did you buy that mudguard?
    670K
