Handlebar for Rise with internal cable routing (motor/gears)
b33k34
Are there any aftermarket options? Need to replace the carbon bar on one of our bikes. Orbea have an aluminium option but does any other manufacture make a bar than will run the motor control cable internally like the Orbea bar does.
If I understand what you're asking for correctly then One up has that option but you need a particular stem.
Oneup carbon e-bar is very nice and has internal routing for the wires.
If you’re interested in the orbea carbon model I have a brand new one for sale. 20mm rise wasn’t enough for me.
That’s the route I took with one of my bikes. Internal cable routing…but the possible nightmare of threading cables thru the stem and into the frame helped change my mind.
Sure it can cleanup the cockpit but servicing the steering components or brake cables can be difficult. Instead I went with the wireless AXS system for the derailer and dropper. I even added the small elbow for the Magura brake master cylinder to tidy up the cables a bit more in the cockpit area.
I like the one up carbon bars though.
Fitted one of the OneUp carbon e-bar's to a mates bike - honestly the cable routing was easy with one of those cheap magnet routing kits off aliexpress/amazon and made for a super clean cockpit
I was so impressed with the feel of the oneup bars that I got a high rise version for my own bike but didn't bother with the cable routing as I've switched to the Kiox 400c and wireless mini remote
Bought PRO (Shimano) Koryak E Performance in both Alloy (which I want - not a fan of carbon as a bar material) and carbon. Similar price RRP as the Orbea but picked up at a 40% discount.
    677K
