I have a 2019 Focus Jam2 with suspected internal battery failure. I want to test the charger and the external TEC battery to check are working 100%, but when I place multimeter probes on main 2 terminals of either the charger or the TEC, I get 0 volts. The TEC has 5 bars, but charger works ok briefly when I plug it in to the TEC, before cutting off due to being fully charged.
Am assuming they need to be "triggered" by BMS on battery before showing volts?
BTW, I,ve opened up internal battery, & tried to reset with no luck. I do get 36v+ on cells, but around 2v on battery outlet, after BMS. What a crap design!
I have also opened the charger, & get 42v briefly on cable outlet when plugging into TEC (before it cuts out as battery is already at 100%) , but nothing when plugged into internal battery.
