Cube EMTB 2026
GDAS
Surrey, UK
It seems the 2026 bikes have been launched today.
Video is in German but subtitled in English.
There is a new full power (CX and CX-R) AMS Hybrid 177, that comes with 600 battery, and can run the 400 battery. (timestamp 31:12), a couple of kg lighter than the Stereo 177 800
The Stereo SLX models and above, come with the Kiox 400C top-tube display
And headset cable routing continues 🙁
Different colours, there's a new evo slx line, no major changes it seems?
Well the AMS 177 is a whole new bike. Some of the Hybrid 144 and 177s come with he new Kiox as standard too. Some spec changes too.
Interesting to note that on the 2026 bikes, Cube's still using the adapter plate for the new Kiox 400c!
On the original 2025 frame they likley made the Kiox hole bigger as they may not have had final dimensions from Bosch at that point and I guess they don't want the expense of a frame revision and the tooling change that would need so ugly plastic gasket/adapter it is.
Do I see that it has the same frame specification for the 2026 bike:
If you like your mountain trails tough and fancy the idea of repeat play, the AMS Hybrid 177 has what you need. Mullet set-up, light C:62® frame, innovative kinematics and geometry, Bosch CX power and 600Wh battery... it's the complete package for gravity taming on your terms.
I did notice that the frame does not have the brace going forward from the rear shock mount. With the 600 battery and high end components I would expect it to be a lighter bike.
It's a different frame from the normal Hybrid One77. The AMS frame is full carbon and looks to have a non (easily) removable battery. Looks like the stock builds come in at 21.5-22kg. So a bit lighter than the Hybrid one77.
just saw in shop... here two One44, all with kiox400c.. SLX has the new XT 8220 and TM the maven bronze (and a new green color that live is very nice)
01-20250904_190028.jpg 02-20250904_190041.jpg 03-20250904_183044.jpg 04-20250904_183031.jpg 05-20250904_183014.jpg
I supose it´s to acomodate the flat kiox shape to the more rounded shape frame .
