My 2023 Whyte E160 has a base Zeb with Debonair+ spring and 160mm of travel.
I am 65Kg and running at 70psi and a little concerned about the unladed fork length.
Lifting the fork by the crown until the wheel is off the ground, I measure 155mm of available fork travel - this seems ok given that there is going to be some residual negative chamber force but I am surprised that don't have the strength to extend it all the way to 160mm.
Letting the fork settle under the weight of the bike in a stand I measure only 140mm of available fork travel. Put another way, there is 12% static sag without any rider weight.
I did perform a lower leg service today and it did make the fork smoother but did not change the static sag or my inability to extend it all the way (at 70psi)
Are these numbers normal and if not what could be wrong?
