Review Rockshox Reverb AXS B1 Dropper Post (Gen 2 2026)
p3eps
Product name: Rockshox Reverb AXS B1 Dropper Post (Gen 2 2026)
Price paid: £535 RRP (£500.43 paid!)
Score (out of 10): 8.5/10
Review: There have been a load of groundbreaking advancements in bikes since I was a kid. Hydraulic brakes and suspension are two that spring to mind, and another is the dropper post.
Back in the old days, I used to carry an Allen key in my pocket for lowering my saddle for the descents. Then came quick release seat posts… and eventually, the dropper post. I got my first one in 2007 when I got back into bikes, and it felt like a revelation… and something I wouldn’t be without anymore.
At the beginning of 2020, I bought my first eMTB - a Trek Rail 9.9 AXS. I’m a sucker for gadgets and tech, and this bike had wireless shifting and a wireless dropper. I rode it for about 2 weeks… and then ordered a Levo SL as the Rail had too much power. I also ordered a Reverb AXS dropper and AXS shifting for it, as even after 2 weeks use, I felt I couldn’t go back to wired.
The simple push button is so easy on the thumbs, and the ability to ‘tap’ the button and drop a couple of mm’s is ideal for technical climbs.
I’ve run a Reverb AXS for over 5 years now. My original developed a fault where it would only return to about 75%, and was warranty replaced - the diagnosis was a bent post. The replacement has been on my bike for over 4 years. No servicing, no maintaining - still working perfectly. Probably not very sensible, but I figured I’d just run it till it died now. I’ve had issues with the cable on my old Stumpy - so the lack of cable is a bonus. The only downside to the Reverb is the maximum length is 170mm…
…until now!!
I picked up the Reverb AXS B1 a few days ago. It’s the second Gen Rockshox wireless post, and is now available in 25mm increments, all the way from 100mm to 250mm. I’ve swapped from a 34.9 x 170mm post to a 30.9 x 200mm post… so an additional 30mm drop.
3 reasons for the width change - the 30.9 can be shimmed to work with any of my bikes (my stumpy is 31.6), I can get a better insertion depth with the slimmer post (I’d have had to take 175mm if I wanted 34.9), and it’s lighter too. Putting them on the scales, the original 170mm x 34.9 post weighed 828g (with battery fitted) and the new B1 200mm x 30.9 weighs just 712g (with battery fitted) and 751g with the shim on.
The new B1 is also cheaper than the original. UK retail price is £535. I had a “spend over £250 get £25 off” voucher with Tredz, and used Quidco to get 3% cashback... so it cost me a few pence over £500.
The downside is that it doesn’t come with a remote. The expectation is that most people have a spare one (I have a couple sitting in drawers), but I’m not sure everyone will. A Reverb remote costs about £80 if you don’t have one… or you can use a POD - which is about £100.
I use the POD with the new ‘rocker’ buttons, and have the second button set for cycling through my Garmin screens.
Even with a remote, the Reverb B1 is still significantly cheaper than the Fox Transfer Neo - which retails at £1129.
Apart from the extra length, what else has changed?
It’s gone from having the electronics discreetly hidden under the seat, to having a bulge at the bottom of the post. This is a similar design to the Fox offering, and looks a bit odd.
Thankfully, I used the SRAM calculator tool (Calculator - RockShox), and got the perfect fit with the electronics right at the base - but others might find that the bulge ends up being further up the post.
My insertion depth just lets me away with the 200mm (in 30.9)- I have the post slammed almost as far as it will go, and it’s the ideal height when extended. 6ft 2” on an S4 Levo SL. If I was an inch shorter I’d need a 175mm, which would have the bulge about 30mm up the post!
The electronics have a light and button on them… and the button on this one is much bigger than the usual AXS buttons. Being where it is, it’s a lot more accessible - so in theory, you could use this without a remote and simply press this button instead. It could be handy if your remote battery randomly died when out on a ride I suppose. As it’s out front, it doesn’t get in the way, and should be shielded better from mud and grime than the original. It just doesn’t look as ‘clean’ as the original did.
The actual seat clamp has gone back to an old school one. It’s a lot more awkward to fit the saddle and adjust, especially mine which has quite chunky oval carbon rails. Something with round rails would probably be much easier - but I ended up putting little strips of black tape on the inserts to hold them in place, as I didn’t have enough hands to reassemble it. I imagine this is behind a decent amount of the weight saving. It’s a set and forget though - so I won’t have the hassle of refitting the saddle again until service time.
Speaking of servicing, the B2 is now an air only post - so no hydraulics in here. This apparently makes servicing much simpler, and the 300hrs / 1 year service can be done in 15 mins without a load of specialist tools. Above 175mm posts are running at 600psi though, so will need an above average shock pump to repressurise it.
There’s a feature called Activeride that is also new. At full extension, the post will remain rigid, however if you drop the post a bit and sit down, Activeride is engaged. This offers a slight ‘suspension’ on the saddle - subtly moving as you go over rocks etc. I can’t say I noticed it, but then I have rear suspension. Perhaps it’s something more designed for a hardtail or gravel bike?
Apart from that, it seems to be the great Reverb AXS post that I’ve loved for the last 5 years. Fast response time, easy to find the right height when dropping a little bit (climbing for example), easy to setup / install (once you get the saddle on!).
A like for like post should be slightly lighter in the B1 configuration, and the battery life is supposed to be slightly better too.
I’ve only managed a few rides with it so far, so time will tell. Initially, I’m really pleased with my additional 30mm and 77g drop in weight!
I've scored 8.5/10 - 0.5 off for not coming with a remote, and 1 off for the ugly bulge!
Nice write up what are you using for shims?
My bike is a Levo SL Frameset that I built up, and it came with the shim. The Levo SL has a 34.9mm seat post, but the the S-Works bikes come with a 30.9mm Reverb AXS and a shim.
Possibly to save Specialized having to have an inventory of different width posts, but probably to help get the weight down!
Thanks for the review. I’m seriously tempted to get one just to avoid the hassle of dealing with internally routed dropper cables in an eMTB.
Realised I can use Cycle2Work with Tredz and get a big discount.
Is there a new remote unit for this or does it still use the same as the previous AXS?
Thanks for the review. I’m waiting to pull the trigger on one but can’t decide on the length to get. I’ve got a gen 3 levo size s5. I’m 6ft 3. The calculator suggests a 200mm. But I want it slammed as much as possible. I’m wonder if a 225 will be better
The calculator was bang on for me. The 200 JUST fits and no more. If I chose a 34.9 post, it would have put me on a 175.
You may not have enough insertion depth for a 225?
No new remote - you can either use the original reverb dropper control or one of the POD controllers.
I use the POD with the rocker switch on it - but it’s all down to personal preference.
Thanks for the review. I called my shop last week and asked them to order one for me. I don't NEED one, but my curiosity has gotten the best of me.
…until now!!
Activeride is there excuse for a piss poor design!!
I'm intrigued by what they did with this one.
How long have you been riding the one that you're not happy with?
How would you have designed it differently?
What other seat post acts like a mini suspension post when in the lower position?
Dropper post are low on my list when I'm doing a custom build for myself. Now this is Mr. T talking.... "I Pity the Fool that can't ride a bike without a dropper"
I was the same - I didn’t ‘need’ one, but I thought I’d give it a try. If I’d only been able to go from 170 to 175, I may not of changed.
Anyone considering one just now - Tredz just put out an email with discount codes.
Spend over £500, and get £55 off.
The code is SAVE55
That'd take it down to £480, and you could potentially get about £9 cashback buying through Quidco.
As far as the active ride, it's something they carried over from the AXS XLPR. The small amount of suspension you get from the post when it's lowered is stellar on my gravel bike. I've had mine for a few weeks, and it seems to be just fine on the MTB. When the dropper is fully extended, it is exactly like every other dropper; it's only when the seat is lowered from full extension that you get the small amount of squish. My only complaints are that the new seat rails are a downgrade from the old version, certainly not as aesthetically pleasing, and I'm hoping the new design is as durable as the previous version.
My previous two AXS droppers both went through 2 different EMBTs and then sold to friends who are still using them. I had well over 8k miles and 500k of climbing on both of those droppers. With regular droppers, I would have gone through at least 3-4 droppers. So, while expensive, the cost works out to be about the same in the long run. Plus, you can just pull the dropper and swap to your other bikes in about 5 minutes. Just my 2 cents.
For the first time ever on this bike, I actually had my tyre rub against my ar5e!
That 30mm extra drop on the post clearly makes a big difference.
There's a couple of very steep bits on the Heartbreak Ridge descent, and being able to lean that little bit further down made me that little bit more confident. I've ridden it 6 times over the last couple of years with the 170mm post, and never had that buzzing feeling 😂
Is there anyway to adjust the amount the post extends when operated? Like being able to set a max height
Hi Can you tell me how to get the pod controller to cycle through the Garmin screens. Thanks
I googled it, as I’ve never managed to set up my AXS as 1 bike in the app.
There was a video that showed you how to connect a dropper / derailleur / pods as a single system. You could then reassign the spare button to whatever you liked. I’ve set mine as 1 press to go forward a screen, and a longer press to go backwards a screen.
I’m on holiday with absolutely pathetic WiFi just now, so there is no chance of me finding the video on YouTube! It’s £26.99 per 100mb of data in Antigua for O2, so my data roaming is off too 😂
Thanks 3Peps Thanks for your reply. I’ll Google that as it seems as though it would be quite useful. The dropper is great now fitted.
A handy feature if you have a spare button. I normally have to swipe the Garmin screen left or right to change the page… which is sometimes tricky taking a hand off the bar. It can also be awkward if the screen is wet or muddy.
It’s a weird procedure to link the 2 controllers and the dropper / derailleur together. I had to attempt it several times until I got it right!
I’d had AXS for 5 years before I had them all paired as single system.
I currently have the prior hydraulic version. While this updated model may offer a bit more travel that my current version, I must admit I'm leery of Activeride, which sounds like a side effect of ditching hydraulics for straight air (as in that hydraulics don't compress whereas air does - hence the 600PSI to keep it stiffer than otherwise at lower pressures).
Can you provide a bit more detail on the differences between this and the prior model you had? Responsiveness, reset, squish factor, float, linearity, seal tolerances, etc?
It's not too difficult, the help video is very useful tbh
I really like Activeride on the XPLR on by gravel bike (Specialized Creo 2 Comp), it's subtle but noticeable Vs lockout.
Not sure it's that useful on a full suspension, unless you have the tail locked.
Having said that I will probably get a B1 for when the EMTB arrives, I prefer fewer cables.
I find it to be beneficial. When I'm striving for maximum power output, the seatpost needs to be up. When I'm hitting the maximum gnar, the seatpost needs to be slammed. The Reverb is rock solid in these positions.
So when do I want the seatpost in the middle? Maybe when I'm hitting it really fast, the trail is chunky or chattery, but I'm so fatigued that I need to sit down and reset for a second here and there. If the seatpost was rock solid, I'd be getting hit in the ass and I'd have to either work harder or slow down. The other time is when climbing super steep chunk. I need the seatpost up a little to manage power output, but when hopping up the features, the saddle can again hit me in the butt. The little bit of cushion is welcome.
If your a superhardman athletic god, then the few mm of squish won't matter, because superhardman gods only ride with their seatposts fully extended or fully squished.
I like to do a really quick press of the button and drop about 5-10mm for technical climbs. I feel it gives me a little bit more stability, and also a bit more confidence that I can get my foot flatter down if I topple!
Researching a new dropper for my ordered e-bike frame and looking at this product.
What's a bummer is that the weight, insertion & charging trouble would be TONS better if they would just hardwire these to the e-bike battery.
If it should be hardwired it would take much longer to install/remove just like a cable dropper. And how difficult is it to charge every second week or make another charge routine
I personally don't care about install time as it's mostly just a 1x deal.
You're giving up all that space and weight of that battery mount. They'd really have something here if it was hardwired. Electronic droppers could actually be 'better' than a cable operated dropper for the first time. They already have better actuation but with a size, weight, cost & maintenance penalty. They could equalize all of those and only have the cost penalty.
Oh well, there is always next gen.
    670K
